Header Gasket Life?
Old Aug 2, 2005 | 11:13 AM
RED99's Avatar
RED99
Default Header Gasket Life?
I am thinking of putting on a set of headers for my 99. But I have one concern! I haven't had a car with headers in over 20 years. Back then it was common for the header gaskets to burn out. If you went a year without changing gaskets, you was doing pretty good. I just wonder if there is an improvemnet these days in getting the gaskets to last longer? So I would like some feedback from you guys that has been running headers on your cars, espcially people that puts 10,000+ miles a year on your car. What your gasket life has been.
Old Aug 2, 2005 | 11:19 AM
BAD_TCR's Avatar
BAD_TCR
Reuse ( or get a new one) the stock metal gasket. With that, you'll be just fine.
Old Aug 2, 2005 | 12:43 PM
vettenuts's Avatar
vettenuts
I actually used the f-body gasket, same construction as the Vette in that it is multi-layer metal. It won't burn out, but a re-torque may be required after a few heat cycles.
Old Aug 2, 2005 | 05:54 PM
The newer gaskets are really quite good and should last for a long time.
To Header Gasket Life?
