Will installing column lock bypass stop my column lock problem ?
Old Aug 3, 2005 | 09:37 AM
Mixman's Avatar
Mixman
Default Will installing column lock bypass stop my column lock problem ?
I have taken my 2000 Vette to the dealer twice for the column lock bypass recall. Now just about every time I start I get the "Pull the key and wait 10 seconds" reminder. I know this isn't right.
Will getting the lock bypass part get rid of this problem ? If not, what else can I do ?
Old Aug 3, 2005 | 09:44 AM
COHMATT's Avatar
0COHMATT
Former Vendor
The bypass will keep your wheel from locking. If your wheel is not locked and you are getting this message you may need to pull the two fuses and see if that helps.
Old Aug 3, 2005 | 10:08 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
If your steering wheel will lock and unlock right now get the CLB and you'll never get the message again. It goes in circuit instead of the CL and simulates the CL. This will stop those messages from coming up. Do it before the CL locks and will not unlock anymore. Keep us posted.
Old Aug 3, 2005 | 10:13 AM
PugLover's Avatar
PugLover
Default column lock bypass
I have a 2001 and do not have the column lock problem, thus far. Should I be concerned? What years had the problem? Any help would be appreciated.
Mark
MSgt. USMC
Old Aug 3, 2005 | 10:16 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
If your car is a 6 speed, and you had the latest GM recall done, the Colum Lock Bypass will keep your colum from locking, however, you could still have problems if your computer or Bypass kit get confused, your fuel will be shut off and you'll still be stuck, since the latest Wonderful GM recall for 6 speeds is only to reflash your computer to shut off fuel supply if it senses a problem with your colum lock.
If you have an automatic, get the Colum Lock Bypass kit, or get the GM recall and you have no worries.
no real fix for 6 speeds
Old Aug 3, 2005 | 10:17 AM
07blackcoupe's Avatar
07blackcoupe
From: Lost in the Pine Barrens with only ketchup and relish packs, New Jersey
Make sure when you took your vette to the dealer that they performed the correct procedure as the procedure changed from year to year and manual to automatic. When I took mine, (99 manual trans) they performed the CLB recall for a 2000 auto because they "STATED" that they performed the recall that came up for my vin #. I think there may be a problem with the computer program that dealers use to decipher vin #'s. I guess it would be too much trouble for them to actually know what the vin # means... (sorry for the minor rant )
Old Aug 3, 2005 | 10:22 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
Read this Thread/Sticky from the C5 Tech section.
Lot's of good info here that should answer your questions.
http://forums.corvetteforum.com/show...483&forum_id=1
Old Aug 3, 2005 | 10:26 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Yes....
Old Aug 3, 2005 | 10:32 AM
Doughan's Avatar
Doughan
Elite Member
Cruise-In III Veteran
Mark
MSgt. USMC
If your Vette is an automatic tranny, then it doesn't have the column lock. GM stopped putting the column lock on A4's starting in 2001. If it's a MN6, get the CLB!
column lock
Old Aug 3, 2005 | 11:06 AM
Mixman's Avatar
Mixman
I have taken it to the dealer twice for the recall. I have a 2000 A4. While the column no longer locks, last week I got stuck, the car wouldn't move far, with my engine getting cut off and I got the message " Service Column Lock".
First if this happens on the road, What is the way I get around this and get my car started ?
Second How do I keep this from happening again ? The dealer said they applied all of the fixes according to the recall from GM and there was nothing else they could do. Would the CLB definitely take care of this or is there something deeper wrong ?
Oh and what fuses should I remove that will prevent this ?
Old Aug 3, 2005 | 11:55 AM
Mixman's Avatar
Mixman
Which two fuses ?
Old Aug 3, 2005 | 01:00 PM
PugLover's Avatar
PugLover
column lock
I tell you this forum is awesome. My Vet is an auto so no worries. Thanks for the info.
Mark
Old Aug 3, 2005 | 01:16 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I've had it on my 2000 MN6 for three years and no problems.
Old Aug 3, 2005 | 01:22 PM
Get the CLB and you should be trouble free from then on. I've had mine installed for a year now and not one instance of column lock.
Old Aug 3, 2005 | 01:27 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
A couple of tips from someone that just went through this 2 days ago :
Make sure your battery is fully charged.
Turn off all electronics (ie. close the door, leave your foot off the brake, A/C, etc)
If the above items don't help, turn your wheel hard to the left and right while pulling down. This last tip was the one that worked for me. THEN you can install the bypass. Installing the bypass on a locked wheel will not help you in the least.
If all else fails, you will probably need to have it towed.
Old Aug 3, 2005 | 01:28 PM
Mixman's Avatar
Mixman
I just talked to my dealer. They said that GM is now telling them to replace the column lock motor and remove the relay put there.
Does this sound right ?
Old Aug 3, 2005 | 01:30 PM
JR_VETTE's Avatar
JR_VETTE
I believe they are talking about the locking plate, not the relay. I'm pretty sure that's the fix for a A4. I have a MN6, so I had to live with their crappy recall that didn't work for me at all.
To Will installing column lock bypass stop my column lock problem ?
Old Aug 3, 2005 | 01:54 PM
Mixman's Avatar
Mixman
Having the wheel lock is no longer my problem. The recall DID take care of that. What didn't take care of is my getting the "Pull Key, wait 10 Seconds" and the "Service Column Lock" messages, with the engine cutting off. This is what I want to cure, both temporarily, if stranded, and permanently if possible.
Old Aug 3, 2005 | 01:57 PM
JR_VETTE's Avatar
JR_VETTE
Wow... I don't know the what the insides of the column lock look like, but it sounds like the locking mechanism is locked again, but the locking plate isn't there, so it's not really locked. In this case, the bypass may actually help you.
I'll wait for someone else with more knowledge to chime in before I carve that assumption in stone.
Old Aug 3, 2005 | 02:04 PM
COHMATT's Avatar
0COHMATT
Former Vendor
Which two fuses ?
#25 and #29
