ignition switch or clb?
Old Aug 3, 2005 | 02:27 PM
rcknusa's Avatar
rcknusa
Default ignition switch or clb?
I haven't done a search and know this has probably been discussed more often than is necessary but I need to ask any way.
Several weeks ago I tried to start the car and when I turned the key the motor turned over once and stopped. Turned the key did it again. I finally giggled the key and turned it, the car started right up. It has happened several times since. I have not seen any message on the DIC about service column lock but do I have the symptoms?
Thank you for your help.
Old Aug 3, 2005 | 02:28 PM
rcknusa's Avatar
rcknusa
I forgot to add. It is a 2000 auto coupe.
Old Aug 3, 2005 | 03:11 PM
rcknusa's Avatar
rcknusa
ttt
Old Aug 3, 2005 | 03:26 PM
Doughan's Avatar
Doughan
Elite Member
Cruise-In III Veteran
It was probably not a column lock issue. You get "PULL KEY WAIT 10 SECS" and then "SERVICE COLUMN LOCK" on the DIC if your column lock is going flaky.
Here's a link to the sticky thread in C5 Tech on the column lock:
http://forums.corvetteforum.com/show...483&forum_id=1
Old Aug 3, 2005 | 07:04 PM
rcknusa's Avatar
rcknusa
Thank you very much that was very helpful and informative.
To ignition switch or clb?
