Memory Settings Issue
Old Aug 4, 2005 | 03:30 PM
dbros9's Avatar
dbros9
Default Memory Settings Issue
I have 2 memory settings coded in my 99. when I unlock the car and start the engine sometimes memory 1 will kick in other times memory 2. Any idea why that is???
Old Aug 4, 2005 | 03:35 PM
sailohio's Avatar
sailohio
Yeh. The numbers corr espond to numbers on the back of the remotes. Open w/ remote one, it'll go to the #1 setting. Number two, ditto.
Old Aug 4, 2005 | 04:09 PM
dbros9's Avatar
dbros9
Default I use the same remote all the time
it is random - i never know what setting will occur when i turn the key on - i never use the other FOB
Old Aug 4, 2005 | 07:16 PM
Tarkdog's Avatar
Tarkdog
I love my car but its the same as yours. I never know what setting I'm going to get. I use key #1 and sometimes it works sometimes not. Every few weeks it will even try to jam me into the dash when I get in.
Old Aug 5, 2005 | 12:26 AM
Lestat712's Avatar
Lestat712
I just set memory positions to be the same on #1 & #2. As I'm the only driver, doesn't matter which key I use.
Old Aug 5, 2005 | 12:36 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check the DTC codes and let us know what codes are set!!
This is the absolute best C5 Code web site!!!
http://www.corvettedoctor.com/Codes_Page.htm
Old Aug 18, 2005 | 06:41 PM
rabranstetter's Avatar
rabranstetter
Default DUH---banging head---
I only got the #2 fob, now it all makes sense for me too!
I guess I will make my settings #2 not #1.
Old Aug 19, 2005 | 12:46 AM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I think it may have something to do with the amount of times you press it as to which memory selection it activates.
Old Aug 19, 2005 | 05:56 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I agree.I have both memory 1 and 2 set the same, the "easy entry" is turned off, and still the seat sometimes moves on it's own.... Maybe the psychic Sylvia Browne is right, and our deceased relatives come back once in a while to bust our chops!
To Memory Settings Issue
