Low coolant sensor?
Old Aug 5, 2005 | 06:33 PM
diviniti's Avatar
diviniti
St. Jude Donor '05
Default Low coolant sensor?
Is it possible the for coolant sensor to fail? My display keeps telling me "Low Coolant" but after checking, the coolant is at the correct level. Is there a way to check the sensor? Or could this be a different issue?
Old Aug 5, 2005 | 08:22 PM
ttaylor's Avatar
ttaylor
Had the same problem on mine. Added about a 1/2 cup of coolant anyway and low coolant warning went away. I guess they have a tight tolerance.
Old Aug 5, 2005 | 08:54 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
The float in the tank can get stuck. I had the same thing happen to me. I had to replace the tank. It comes with a new sensor
Old Aug 5, 2005 | 09:51 PM
towercontroller's Avatar
towercontroller
happened to me. you have to replace the whole reservior. easy job, $60 from dealership
Old Aug 5, 2005 | 10:28 PM
LB04CE's Avatar
LB04CE
Had that to happen on our 99 put in 1 cup of coolent went
away. Might be all that is wrong with yours. GOOD LUCK
Old Aug 5, 2005 | 10:53 PM
KonaVette's Avatar
KonaVette
St. Jude Donor '03-'04-'05
Mine will do this if only I am on a steep grade. Better check out the level this weekend just in case.
Old Aug 6, 2005 | 11:20 AM
diviniti's Avatar
diviniti
St. Jude Donor '05
thanks guys.
To Low coolant sensor?
