tire sensor question
Old Aug 7, 2005 | 02:31 AM
LT1driver's Avatar
LT1driver
Default tire sensor question
my front fikse wheels (zo6 style) will not take sensors due to way rim made, question is can I run only the back sensors without getting messages of front error etc., turn only the back on-will this work????
Old Aug 7, 2005 | 02:33 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
No sensor...you are going to get the message. I tried to clear the code, but was not successful in doing so...similiar to what you are asking. I had sensors not reading and wanted to just tune them out or remove a fuze, but no go.
Sorry.
Micah
Old Aug 7, 2005 | 02:44 AM
GrayC5's Avatar
GrayC5
Originally Posted by LT1driver
...can I run only the back sensors without getting messages of front error etc., turn only the back on-will this work????
Nope. If your car is a model year 2001 or later, you can have your dealer edit/delete the tire pressure monitoring programs from you car's computor so you don't get the error message. For earlier model years, you're out of luck.
Old Aug 7, 2005 | 02:47 AM
GrayC5's Avatar
GrayC5
Nope. However, if your car is a model year 2001 or newer, you can have your dealer edit/delete the tire pressure monitoring programs from you car's computor so you don't get the error message. For earlier model years, you're out of luck.
Old Aug 7, 2005 | 07:32 AM
Without all the sensors in place, you will get an error message. May have to get some band clamps and put the fronts on too.
Old Aug 7, 2005 | 11:10 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just install the sensors in the rims using a band clamp and some epoxy. Then you will have sensors and no error messages!
BC
Old Aug 7, 2005 | 03:28 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
BC
Why not have the extra degree of warning when a tire has low pressure. I think there will be a day soon when the government makes TPS standard safety equipment on all cars.
Old Aug 8, 2005 | 04:11 PM
LT1driver's Avatar
LT1driver
thanks guys, once again forum members come thru with the answer, i agree in the very near future all cars will have tire pressure sensors, think i read around 2008, due to firestone fiasco. thanks again for responses
To tire sensor question
