HID Lights
Old Aug 9, 2005 | 12:20 PM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Default HID Lights
Anyone know what happened to the member that was developing a HID replacement headlight? Post ran on for several months with "progress" reports. Now nothing. What happened?
Old Aug 9, 2005 | 03:26 PM
SFengineer's Avatar
SFengineer
I've been running BMW E46 hid projectors now for almost a year, and recieve compliments are inquiries every time i drive at night. I had an overseas manufacturer ready to create a complete mold, but held off in respect to the guy who was going to make the original set. I think it's been enough time. If the interest is there, i'll start checking around again
Old Aug 9, 2005 | 03:33 PM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
Interesting!!!! From where did you pick them up and how much? PM if you must!
Old Aug 9, 2005 | 03:38 PM
JTS97Z28's Avatar
JTS97Z28
I am running Valeo e-code projectors (audi A4/S4) in my stock housing. Some of you may remember my post several months ago. I paid $410 shipped for the projectors, Philips D2S bulbs, and Hella Ballasts. Took a ton of time and effort but now its done and they are amazing. Do a search for my name you will see the original thread with pics.
Hope this helps.
JT
Old Aug 9, 2005 | 04:02 PM
SFengineer's Avatar
SFengineer
Mines similar to an HID retrofit. As mentioned before, it takes a hell of a long time, and I wouldn't feel 100% confident in marketing something that doesn't have a strict quality standard. I cut the back of the housing out and used our plastic welder to seal in the projectors. As far as making them DOT legal, that's a whole different story. I have never once been flashed while running them, and i've put about 10k miles on my car, most of them at night. New DOT requirements call for motors to be put on them, to level them out if say, you put 10 - 60lb bags of concrete in the back of your car. Makes sense, the cutoff line would be much higher, and therefore blinding oncoming drivers due the front of the car sitting up at an angle. On our vettes though, we never load them! I'll take some shots tonight of the cutoff lines and down the road illumination.
Old Aug 9, 2005 | 04:56 PM
TOOGECKO's Avatar
TOOGECKO
I have been sitting on my hands waiting for this "new" kit to come out, afraid to drive at night because I can't see with the stock lights (a lot of deer around here). Somebody come out with a kit that replaces the light and the cheap plastic lens! Please!
Old Aug 9, 2005 | 08:44 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Try doing the 9005 headlight conversion. You shouldn't have to drive blind, the deer will thank you.
Old Aug 9, 2005 | 10:36 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
by simply puttin in a HId kit, u can better your stock output... i know, some of u may be thinkin, ohh, but that blinds oncoming drivers, blah, blah, blah...but hey, aim them right and your golden!
now im running the C5R lights with an 8000K kit, and man, its like im driving a benz or something german. the light output is controlled and there is a cutoff. never been flashed once!
the kit you are thinkin of is being "made/designed" by Mray on this forum. last i heard, he is making the pop-up kit. soon to follow the non-pop up. i "think" he got the projectors DOT approved... not sure.
i too was waiting for this, but i came across a deal on a set of C5R's and said the heck with it. took on the challenge of installing them. not as hard as most would think, just time consuming if your a perfectionist (which i assume most of us are, LOL)
Aj
Old Aug 10, 2005 | 02:14 AM
SFengineer's Avatar
SFengineer
pics as promised. So far, lights have been 100% trouble free for a year. Don't have pics of the high beams, completely forgot. They're just as bright, but doesn't use the cutoff, so there's light everywhere
Inside Car
Outside car
Under cutoff
Projector
Cutoff (reflections above cutoff)
Behind car
Old Aug 10, 2005 | 08:32 AM
TOOGECKO's Avatar
TOOGECKO
SFengineer - you taunt! So are you gonna offer these up? How much did it cost you and how much modification to the stock system did it take?
Old Aug 10, 2005 | 08:56 AM
BAMF AE's Avatar
BAMF AE
WOW!!! Looooove those lights! Seriously! Thank you for sharing them. Cutting, welding, sealing...... Definitely no task for an amatuer!
Old Aug 10, 2005 | 08:58 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Old Aug 10, 2005 | 10:51 AM
SFengineer's Avatar
SFengineer
The total cost for the system was about $450, using genuine Bosch Bi-xenon projectors ($230, used), ballasts, and D2s bulbs. Going with standard projectors would have cut the costs by about $50, and going with a ballast other than Phillips would have saved another $50. So total cost for the whole HID setup, including projectors, could be around $350 using generic parts. I wanted the Bi-xenon, which puts an unbelieveable amount of light on the road when the high beams are activated. Honestly, turning on the cars stock high beams with this system on looks like you just turned your DRLs on at night.
The overseas manufacturer created this light, they can do one to mount directly to the C5's mounting brackets. They're good at doing the halos too, and they don't really add any additional costs.
Old Aug 10, 2005 | 12:28 PM
TOOGECKO's Avatar
TOOGECKO
Well, I'd be interested as I'm not convinced there is a good kit available right now...
Old Aug 10, 2005 | 01:45 PM
AMGPilot's Avatar
AMGPilot
SFengineer,
I am interested in the lights you have. Are they DOT approved?
Old Aug 10, 2005 | 03:21 PM
SFengineer's Avatar
SFengineer
Halogen versions are easily DOT approved, but with HIDs, they're requiring leveling motors for when the back of the car is weighted down. Personally i never load my vette with heavy things in the rear, and to date, i've never had a problem.
Old Aug 10, 2005 | 04:15 PM
AMGPilot's Avatar
AMGPilot
Thank you for the reply SFengineer
The C6 HID Lamps aren't self leveling as far as I know. I thought that a self leveling lamp was only required in Europe, along with washers.
I could be totally wrong
To HID Lights
Old Aug 10, 2005 | 04:39 PM
Sportsdude's Avatar
Sportsdude
Nothing wrong with a little competition Too bad your version isn't out already. I've been waiting for the HID from Mray but not sure what the status is. It has been a very long wait.
Old Aug 10, 2005 | 05:18 PM
SFengineer's Avatar
SFengineer
It's made all the difference in night driving. Seems like the interest is there, i'll see if i can get a definite price. For a non hid setup, shouldn't be more than $250, and hid's could be used in it, just the cutoff wouldn't be as clean. This would be for those running 9006 HID's in their stock housing right now. Generic HID lights shouldn't be more than $350, and Bosch xenon or bi-xenon would have to be set by market price.
I'll try and get some hi beam pics up tonight. The hardest part is finding a part of town that's not lit by streetlights! I had to go to the ghetto to get those shots last night!
Old Aug 10, 2005 | 05:19 PM
AMGPilot's Avatar
AMGPilot
Last post I saw from Mray, on July 18th, he stated that they would be ready sometime in September.
