CAGS Eliminator Problem
Old Aug 12, 2005 | 09:30 AM
baylee2011's Avatar
baylee2011
Default CAGS Eliminator Problem
Took my 04 into get a new C6 shifter installed and told them to put the "CAGS" in while doing so. When I picked it up they said the "CAGS" would require two hours of labor because the whole exhaust system would have to be dropped in order to access the solenoid. Is this something exclusive to 04's or are they missing something?
Old Aug 12, 2005 | 09:43 AM
GRAY BEARD's Avatar
GRAY BEARD
Check your other post. There is nothing hard about this mod. Unplug and replug....no kidding that's it. NOTHING else.
Old Aug 12, 2005 | 09:57 AM
fop91's Avatar
fop91
Default CAGS Install
Put a cags on my 04 coupe and it took longer driving it up on my ramps then installing. What a rip off Dealer you have.
TkitPlz's Avatar
TkitPlz
Old Aug 12, 2005 | 10:07 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
OMG 2 hours of labor - wholly Rip off Batman. The exhaust is not even in the way of the CAGS. You can do it yourself in 2 mins or less.
The CAGS goes on the driver side by the Transmission about 3/4 way back from the front of the car.
It is so simple to put in.
Old Aug 12, 2005 | 10:08 AM
charlie78's Avatar
charlie78
I think I'd find another place to take my car in for maintenance. And I'd do it sooner rather than later. They just trying to get into your cookie jar for a couple of hours labor charge. The toughest part of the procedure is getting your car in the air to work on it. I installed the CAGS by-pass in about 5 minutes, and three of those minutes were spent seperating the connector at the tranny so the bypass could be plugged in.
Old Aug 12, 2005 | 10:19 AM
Dave1998's Avatar
Dave1998
I put mine in this week in 5 miutes. You will spend more time gettng the car in the air to get under it. It is very simple and exhaust is not in the way.
Old Aug 12, 2005 | 12:38 PM
DavesC5's Avatar
DavesC5
Same here.
Old Aug 12, 2005 | 12:40 PM
bozo4onion's Avatar
bozo4onion
2hrs.
steve8's Avatar
steve8
I put mine in the other day when I did my first oil change. Had it up on a lift, and it's taking me as long to type this as the insatll did.
Old Aug 12, 2005 | 12:43 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
And how much are they charging you for the shifter?
That Install of CAGS takes 5 mins. It takes longer to get the car up to get under there.
Old Aug 12, 2005 | 03:02 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
they must be thinking of someother CAG
...plug and play...
I can do it in 2 minutes...not 2 hours
Old Aug 12, 2005 | 03:06 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I'd be happy to take two hours doing it ...
Ramp the rear of the car.
Plug in the CAGS E.
Lower the car.
Then go and have lunch for an hour and 50 minutes!
Excuse me for putting it this was - but WTH is wrong with these people? Do they think car owners don't talk to eachother?! Geez us!
I think the name of the place doing the work should be posted ... just for "info"
Old Aug 12, 2005 | 03:26 PM
RED99's Avatar
RED99
Maybe they thought you said Cats.
Old Aug 12, 2005 | 03:56 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
2 hours Yeah, and it should take 6 to install a CLB...
Tom/99's Avatar
Tom/99
It took me longer to jack up my 2004 coupe, than it did to plug in the CAGS eliminator. I just used a floor jack, crawled under it, unpluged the origional connector, plugged in the CAGS eliminator, wire tied the old one in place, crawled out from under the car, let the jack down, and went for a test drive. Do it yourself, it's an easy mod.
Old Aug 12, 2005 | 04:58 PM
StuzVette's Avatar
StuzVette
Plug in the CAGS E.
Lower the car.
Dave...I hope it was as just that they misunderstood what was being asked of them...that request being clear and the time required certain...
...then I wouldnt mind seeing baylee2011 post the name of the company and the service advisor...under these circumstances...
To CAGS Eliminator Problem
Old Aug 12, 2005 | 06:35 PM
MyVetteDream
You're right Stu.
I let things like this irritate me and I know I shouldn't, but it reminds me of this one "trusting soul" I know locally ...
He took his car to a local tuner and they charged him $900.00 to change his OEM brake line to SS ones!
...I was with several other people (we were replacing his calipers) when he mentioned this ...
One guy dropped a wrench when he heard the news. I think we all asked him several times to confirm ... no one could believe that was all he had done. Just a trusting guy ... we couldn't believe it ... dnd an unscrupulous mechanic/ Corvette Specialist at that.
I made him pinky promise he'd call and ask one of us before paying for something like that in the future.
Old Aug 12, 2005 | 06:40 PM
brucksch's Avatar
brucksch
It took me longer to read this then to install the CAGS
Old Aug 12, 2005 | 06:41 PM
deputy_dog1192's Avatar
deputy_dog1192
What exactly is "CAGS"? Sorry for the stupid question.
