My display keeps showing the tire sensor display. Can I buy the sensors for the rims and have the dealer install to remove that malfunction? Are they year specific or rim specific?
I would also like to know the answer to this question. A friend of mine claims the DIC can be set up to remove the tire pressure readings. In other words if you have 4 wheels and tires on the car with no sensors it can be set up so you dont have to reset the DIC all the time. Does anyone know how to do this?
The sensors will go in any wheel & are about $150 each. Not year specific. I do not know how to disable the DIC error message but I hear you can do it on 01 & newer models.
There are two different sensors, one for 97-00 and one for 01-04's. They cannot be mixed, nor will one work on the other years. The receiver was changed mid model. On '01's and up you can have the TPS turned off with a computer change like LS1Edit. It cannot be disabled on 97's-00's...period. The dealer, or any good tire place will be able to make the swap for you. You might also try retraining the offending sensor first. Use this TechTip:
Does it go by the car year or the rims model year? ie 98 C5 with 02 Z06 rims???
By the car year. The OEM rims will all accept all sensors. Most aftermarket wheels will accept the sensors as well with a few notable exceptions. You need the '97-'00 sensors to work with the receiver that your car has.
