Oil Filters?
Old Aug 15, 2005 | 02:24 AM
SLPRC5's Avatar
SLPRC5
Originally Posted by Dave68
The K&N filter out-flows almost all others, while still filtering extremely well. In addition its higher flow rate quiets the lifter-tap noise that is common to many C5s. I have tried the Mobil-1 and ACDelco, but feel that the K&N is most effective in this area.
Very good filter, it has a "nut base" for removing and installing. The K&N oil filter # is 1007. My $.02
Old Aug 15, 2005 | 05:44 AM
Vette_Fan's Avatar
Vette_Fan
I'm running K&N Filter, with 10-30 Mobil1 oil. Doing well...
(The filter has a nut style to use socket for easy intall and uninstall)
Old Aug 15, 2005 | 07:35 AM
Husker67's Avatar
Husker67
Originally Posted by 71corv
Mobil 1 filter here.
Gene
Old Aug 15, 2005 | 07:39 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
What Wilfulone said...
Thanks Chip...you have been very busy!
StuzVette gets Mobil1 synthetic
Old Aug 15, 2005 | 08:25 AM
I use the AC PF 46 on mine.
Old Aug 15, 2005 | 12:39 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Been wanting to try the K&N filter. Anyone know the right # to use on my 02 coupe? And who carries them?
Old Aug 15, 2005 | 09:05 PM
C5Jim's Avatar
C5Jim
Originally Posted by Jim2003
I am a legalist so I use the ac delco filters and always have.
One additonal thought - many years ago on my Buick Grand National I learned about magnets on the oil filters. So for the last many years, (the Buick GN, 97 Camaro Z-28, and now the 03 MN6 Vette) I have put a filter mag on the side of the filter. I can not prove any difference, but if there is a small piece of metal floating around in there, the magnet will get it of the filter material does not. I take the filter off the engine, then take the magnet off of the filter. Just my .02 worth.
GM sells a magnetic oil drain plug for the C5. It cost around $5. Looks exactly like the OEM plug on there now except it has a magnet at the tip.
I use it and it works great.
Old Aug 16, 2005 | 01:36 PM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Amsoil SDF-32 Here. Also use mag drain plugs everywhere, and Amsoil fluids. 42,000 miles on my 02 Z06. Works great!
Old Aug 16, 2005 | 01:50 PM
jrose7004's Avatar
jrose7004
On my last oil change I went with the K&N filter, all others before I used the Mobil 1 filter!
