Oil Filters?
Old Aug 14, 2005 | 07:06 PM
Lestat712's Avatar
Lestat712
Default Oil Filters?
Will be doing my first oil change and want to know what filter I should get. I want to pick it up locally at a parts store (AutoZone, Advance Auto, NAPA, etc.) as I don't want to wait for mail order. What is everyone's choices?
Old Aug 14, 2005 | 07:20 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I always use Napa Gold. I use them on all of my cars. Never had a problem. Very good quality filter.
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Everything you ever wanted to know...
The purpose of an oil filter is simply to filter out foreign particles from the oil that will damage the engine. The primary factors for a filter are the size of particles it will capture and the flow rate it will sustain.
Obviously you want a filter that can maintain acceptable flow, while removing the most amounts of particles. Oil flow is critical for lubricating a performance engine, while particle removing is important for engine longevity.
If you had a pure racecar you would want a filter with the best flow, since you would be replacing the oil every race and engine life is not relevant. For a streetcar engine life is very relevant.
The UPF44 filter is a Gen-3 Synthetic non-woven laminate filter that is actually made by Champion Labs for AC Delco.
The Mobile-1 filter is a Gen-5 Synthetic non-woven laminate filter that is actually made by Champion Labs for Mobile-1.
The AMSOIL SDF filter is a Gen-12 Pressed Cellulose filter that is actually made by Baldwin for AMSOIL.
There is no correlation to generations between Synthetic and Pressed Cellulose filters, only between themselves.
The real comparison of these filters can be easily expressed by their Pore Sizes and Flow Rates. The key is to balance flow vs. filtration. Remember that flow is also relative to overall particle removal. If a filter flows twice as fast, then the oil will travel though the filter twice as often and remove more particles.
Fram TG8= Lg Pore>40 / Smallest Pore>15 / Average Pore>41
Fram TG8= Flow@ 20psi = 4.3 gpm Raw Media / fl-oz/in³/min>2.02
Purolator = Lg Pore>43 / Smallest Pore>10 / Average Pore>42
Purolator = Flow@20psi = 3.8 gpm Raw / fl-oz/in³/min>1.49
UPF44 = Largest Pore>45 / Smallest Pore>17 / Average Pore>43
UPF44 = Flow@ 20psi = 3.0 gpm Raw Media / fl-oz/in³/min->1.97
Mobile-1 = Largest Pore>56 / Smallest Pore>16 / Average Pore>52
Mobile-1 = Flow@ 20psi = 5.3 gpm Raw Media / fl-oz/in³/min>2.27
AMSOIL = Largest Pore>52 / Smallest Pore>17 / Average Pore>50
AMSOIL = Flow@ 20psi = 9.5 gpm Raw Media / fl-oz/in³/min->3.58
WIX = Largest Pore>65 / Smallest Pore>19 / Average Pore>58
WIX = Flow@ 20psi = 5.9 gpm Raw Media / fl-oz/in³/min->2.50
Fram X2= Largest Pore>61 / Smallest Pore>23 / Average Pore>57
Fram X2= Flow@ 20psi = 8.5 gpm Raw Media / fl-oz/in³/min->4.49
From the above list you can see that the UPF22/Mobile-1/AMSOIL filters are all high-flow “small particle” filters. The WIX/FRAM X2 filters are “large particle” filters. They will leave more particles in our oil, but generally flow faster. Fram TG8/Purolator are low-flow “small particle” filters that will clean the oil well, but restrict oil flow though the engine greatly.
I personally would not put a large particle filter on a modern performance engine like our Z06’s. They do not meet the standards specified by GM. I would also not use a very restrictive filter like the Purolator. For the oil filters that flow well with good filtration, the results are obvious.
The Mobile-1 filter flows at almost twice the rate as the UPF44, while filtering out the same particle sizes. The AMSOIL flows at 3 times the rate, while filtering out the same particle sizes.
This is the difference between OLDER generation filter technology and newer generation filter technology. All the good filters (UPF44/Mobile-1/AMSOIL) will also last significantly longer then the junk filters. In case you don’t change your oil as often as you should.
The UPF44 is a very good filter overall. It is however not the best by any means.
Peace
Willfulone
__________________
..................Click for
Old Aug 14, 2005 | 07:44 PM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
I like Mobil 1 Oil&Filter- Great info
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Wow.....nothing to add to Chip's post above me.
I use the UPF44.
Old Aug 14, 2005 | 07:55 PM
FXWG's Avatar
FXWG
Great info, Thanks. Since I change oil every six months regardless of mileage I will stick with the Wix filter. I get them at www.filter1.com. We use them on all of our Mack trucks, Peterbilt truck and all of our Caterpillar and Case equipment without any problems.
Old Aug 14, 2005 | 09:02 PM
Lestat712's Avatar
Lestat712
[QUOTE=Willfulone]Everything you ever wanted to know...
WOW!!! Great information. Thanks!!!!
Old Aug 14, 2005 | 09:44 PM
C5Jim's Avatar
C5Jim
Willfulone
Excellent information on the general workings of an oil filter.
One thing that also should be mentioned is a filter's capacity to hold the contaminants (dirt) that it has removed from the oil.
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
I normally use A/C Delco. But the Mobil1 and K&N are good too..
Steve
Old Aug 14, 2005 | 09:58 PM
DRR's Avatar
DRR
Mobil 1 or Amsoil. Thanks Chip I was afraid to ask. Doug
Old Aug 14, 2005 | 10:03 PM
71corv's Avatar
71corv
St. Jude Donor '08
Mobil 1 filter here.
Gene
Old Aug 14, 2005 | 10:12 PM
Dave68's Avatar
Dave68
The K&N filter out-flows almost all others, while still filtering extremely well. In addition its higher flow rate quiets the lifter-tap noise that is common to many C5s. I have tried the Mobil-1 and ACDelco, but feel that the K&N is most effective in this area.
Old Aug 14, 2005 | 10:17 PM
rws.1's Avatar
rws.1
Mobil 1 or K&N are the only filters I use on my two Vettes
Old Aug 14, 2005 | 10:18 PM
Shylor's Avatar
Shylor
The OEM filter PF46, if it is good enough for GM it's good enough for me.
Old Aug 14, 2005 | 10:23 PM
Jim2003's Avatar
Jim2003
I am a legalist so I use the ac delco filters and always have.
One additonal thought - many years ago on my Buick Grand National I learned about magnets on the oil filters. So for the last many years, (the Buick GN, 97 Camaro Z-28, and now the 03 MN6 Vette) I have put a filter mag on the side of the filter. I can not prove any difference, but if there is a small piece of metal floating around in there, the magnet will get it of the filter material does not. I take the filter off the engine, then take the magnet off of the filter. Just my .02 worth.
Old Aug 14, 2005 | 10:34 PM
MDriveMode's Avatar
MDriveMode
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Old Aug 14, 2005 | 10:53 PM
vetteship's Avatar
vetteship
This forum is simply Great,
To Oil Filters?
Old Aug 14, 2005 | 11:07 PM
Shylor's Avatar
Shylor
Good advice, I also use a magetic oil drain bolt.
Old Aug 14, 2005 | 11:54 PM
Tom73's Avatar
Tom73
If it passes their testing, why use anything else.
Old Aug 15, 2005 | 01:11 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Peace
Willfulone
I like the Supertech by champion labs
Going to look at the upf -44 ac didn't think it was a champion
labs. Still don't like the a/c's
