Dual Zone A/C temp problem
Old Aug 15, 2005 | 08:54 PM
vettezeke's Avatar
vettezeke
Default Dual Zone A/C temp problem
I am getting hot, or hotter air out of the driver side vents on the dual zone a/c than the passenger side while cooling. I had the dash off and pulled the #18 and #27 fuses out to do a control reset on the a/c and the temperature control doors seemed to work right at that time, but the left side has been hotter since. I replaced the a/c auto control head when I got the car because the display light was out so its new. Is there a seperate ground for the left and right temp control dampers or are the prone to intermittent operation when they fail?
Old Aug 16, 2005 | 09:59 PM
vettezeke's Avatar
vettezeke
Default Dual A/c Problem
I got into the DIC tonight and found all of the trouble codes the car had ( which were all history ) and I cleared them which seems to have fixed the air temp control damper. Two of the codes were a/c related. Just incase anybody else has the same problem.
Old Aug 21, 2005 | 04:51 PM
FAAASTJEDI2000's Avatar
FAAASTJEDI2000
Can you send me some detailed instructions on how you did this trouble code pull and clear? I am having similar dual zone, volume, and location probs.
Old Aug 21, 2005 | 05:03 PM
rickko's Avatar
rickko
http://www.dustingarner.com/diccodes.htm
..rickko..
To Dual Zone A/C temp problem
