engine removal c5
Old Aug 18, 2005 | 08:41 PM
speedyjoe's Avatar
speedyjoe
Default engine removal c5
can i remove the engine from the top of the car or does it need to come
from the bottom
Old Aug 18, 2005 | 08:43 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Supposedly it can come out the top. I beleive you need to take off the heads to clear the cowl. But I have heard it is easier to come out the bottom..
Old Aug 18, 2005 | 10:12 PM
The engine is designed to be dropped out of the bottom by removing it along with the front suspension.
Old Aug 18, 2005 | 10:17 PM
vettes4fun's Avatar
vettes4fun
You must remove it from the bottom. The oil pan will not clear the frame. I just installed one today in a 2001 Z06 at my shop it's not to bad of a job. But you must have a lift.
Old Aug 19, 2005 | 01:04 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
I'm sorry Sir but i must respectully disagree. It can be done, it is just a lot of work.
I asked this same question to a few people. Mike Norris for one said that he HAS taken a motor out the top however he probalby wouldn't do it again, and it was too much of a pain. I can assure you unless i can figure out how to pick my car up over my motor...Sometime next year I will be pulling my motor out the top of the car.
Chris
Old Aug 19, 2005 | 07:53 AM
vettes4fun's Avatar
vettes4fun
anything possible but use your common sense. Do it right the first time
Old Aug 19, 2005 | 08:27 AM
speedyjoe's Avatar
speedyjoe
rod bearing gone will a ls2 motor wire up with no problem is it worth the work
Old Aug 19, 2005 | 10:57 AM
KABAL182's Avatar
KABAL182
hey speedy joe . the are selling the ls7 as a crate motor. that would be pretty nice. good luck with your job.
To engine removal c5
