C5 Emblem Modification
Old Aug 17, 2005 | 02:54 PM
indy300's Avatar
indy300
Default C5 Emblem Modification
Has anyone replaced the flag inserts on their front and rear C5 emblems? How is it done?
I have a navy blue coupe that has the black outline emblems. I want to change from the black outline to a gray outline to stand out a little more and match my gray interior and gray wheels. I just thought of buying 2003 AE emblems that are gray but have the AE red (dark red) flag. I think I can swap out my current bright red flag into the gray AE emblem. Any thoughts?
I thought about using the 2004 LeMans emblems, but I was told the "24:00 hours" insert is attached to the emblem unlike the 2003 AE emblem? Is that true?
Thanks in advance!
Old Aug 17, 2005 | 03:31 PM
Patches's Avatar
Patches
Yes, the colored inserts, the checkered flag and fluer-de-lis, can be replaced. In fact, vendors here sell replacement American flags inserts that replace the fluer-de-lis. It's also true that the 24 Hours portion of the '04 is molded into the main emblem body so you would need to trim it out. Incidentally, the silver '03 emblems are painted silver.
Old Aug 17, 2005 | 03:33 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Thanks in advance!
See em on eBay all the time.
Old Aug 17, 2005 | 05:24 PM
The flag inserts are just held in with some glue. You can probably take a thin screwdriver and pop the inserts out. Then just glue new inserts in.
Old Aug 17, 2005 | 06:47 PM
kdzdds's Avatar
kdzdds
Finalist 2022 C1 of the Year - Unmodified
I have replaced the OEM flag and Chev. fleur-de-lies in my '02 and replaced with the cool American flag and racing flag (West Coast Corvettes)... used my wife's hair dryer to soften the original and then gently pried out the old and immediately placed the new (while warm) and everything looks great.
Old Aug 17, 2005 | 06:49 PM
dragon84's Avatar
dragon84
check out what I did with some chrome emblems and the 50th badges.
Old Aug 17, 2005 | 07:57 PM
VetteramI's Avatar
VetteramI
St. Jude Donor '05-'06-'07-'10
That's sweet....er what are we supposed to check out?
Old Aug 17, 2005 | 08:00 PM
dragon84's Avatar
dragon84
Ummm, the picture of the chrome badge and the 50th emblem right under what I typed.....
Old Aug 17, 2005 | 08:02 PM
indy300's Avatar
indy300
That "50th" is just a lay-in, correct?
Who else has modified their emblems??? Lets see'em
I think it would be neat to have them airbrushed on... :o
Old Aug 17, 2005 | 08:07 PM
dragon84's Avatar
dragon84
I had to cut the 50th off of the original emblem from my car. They were on the same tape pad. I have seen them sold seperately.
Old Aug 17, 2005 | 08:25 PM
indy300's Avatar
indy300
On the same tape pad? Do you mean they are not physically attached (molded, glued, etc) to the flags and ring? If thats the case I can just buy the 2004 CE emblems and easily remove the "24:00 hours" piece and not have to worry about switching flag pieces.
Old Aug 17, 2005 | 08:35 PM
dragon84's Avatar
dragon84
Yep. Actually, now that i think about it. I lost a 50th emblem off the rear and I purchaces and entire 03 50th emblem. I then cut the 50th piece out and used it on the rear chrome one on my car.
Old Aug 18, 2005 | 10:50 PM
pewterwest99's Avatar
pewterwest99
WHERE?????
Old Aug 18, 2005 | 11:50 PM
z06nut's Avatar
z06nut
May I have the insert if you are not going to use it?
The CE emblems cost about $80. Are you sure you want to go with them. The inserts for the 50th are smaller and doesn't fill in the area where the flags cross. The CE emblem insert is "V" shaped to fill in the gap. It is not molded to the emblem. It think it can be bought separately. Prior to the Corvette Team running the new Le Mans blue painted C5R at Le Mans, they made inserts that said 3 wins @ LM. When they didn't win first that year. They made the "2 win at LM" inserts.
Old Aug 19, 2005 | 11:31 AM
dragon84's Avatar
dragon84
Originally Posted by pewterwest99
WHERE?????
You should see 2 pics in my sig. One of the pedals I painted and the other is of the emblem.
To C5 Emblem Modification
