Getting Frustrated! Now leaking gas!
Old Aug 22, 2005 | 07:07 AM
ScottP1985's Avatar
ScottP1985
Default Getting Frustrated! Now leaking gas!
OK, so I take the vette in for the leaky butt syndrome. They said they couldn't find the source of the leak, even though I told them EXACTLY where to look. Fine, I'll wait till it leaks faster, so I take it home and now I smell gasoline! I put it up on ramps and under the left tank is an aluminum pan with little slots cut into it, and they are damp with gasoline...not dripping mind you, but weeping enough to keep them damp with a little gas hanging wanting to drip.
I thought maybe they put gas in and spilled some through the overflow, so I ran about 50 gallons of water through the overflow (the drain under the fuel filler) to rinse the fuel from whereever it goes. Water ran out from those same slits in the aluminum pan...I drive it to dry the water out and this morning it is still reeking to high heaven of gasoline.
So...what to do? Take it in??? ANyone have anything like this? If I drop the wheel well liner can I see what's going on? Anyone know how accessible the hoses to the left tank are with the wheel well out? Is it easy enough to pull the wheel well out? Or will the tank need to be dropped?
ANY advice at this stage would be a great thing...
Old Aug 22, 2005 | 07:54 AM
Mark-44's Avatar
Mark-44
Fuel Filter... fix it fast the gasoline is leaking on the exhaust pipe!!!!
Old Aug 22, 2005 | 08:07 AM
ScottP1985's Avatar
ScottP1985
It's an '04 coupe...I believe the fuel filter is in the tank, correct? I might be wrong, and it doesn't seem to be leaking on the exhaust, but to the left of it, on that pan that holds the left tank in place. (the exhaust is in the center)
Old Aug 22, 2005 | 08:43 AM
Mark-44's Avatar
Mark-44
Sorry.. Mine is a 97 and gave me some very anxious moments.. Good to know problem was solved on the newer C-5's...
Good luck.
Old Aug 22, 2005 | 08:48 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Id start by making certain that the fuel pump is tightened down securely...
you will need to remove the aluminum covers to get to the fuel pump..
...then to the fittings...
Old Aug 22, 2005 | 10:01 AM
ScottP1985's Avatar
ScottP1985
The covers hold up the tank, so I'd have to drop the tank? Is this difficult? Could I access anything from the wheel well? I'm nervous about dropping the tank...don't know how difficult it is...
Old Aug 22, 2005 | 12:29 PM
HummelS's Avatar
HummelS
I believe there is a recall on '04's due to a faulty fitting between the tanks. Personally, I wouldn't drive it.
Old Aug 22, 2005 | 02:15 PM
ScottP1985's Avatar
ScottP1985
OOH! Any info on that would be appreciated! I'd have to take something to the dealer though to give them a heads up, since I haven't had any notice yet...
Old Aug 22, 2005 | 04:46 PM
boatboatboat's Avatar
boatboatboat
My 04 is leaking and will get fixed this week. i have looked and looked for a TSB and can't find one. I have heard from someone I trust, that there is a TSB out there about this problem.
To Getting Frustrated! Now leaking gas!
