battery going?
Old Aug 22, 2005 | 08:06 PM
Neeko's Avatar
Neeko
Default battery going?
Lately ive been noticing when i go to crank her up it sounds like the battery is weak. Gauge looks normal when running, everything is lit up and running, etc. Could it just be time for a new battery? Just past 77k miles on her. Thanks,
Old Aug 22, 2005 | 10:47 PM
Blue Lion's Avatar
Blue Lion
If you have 77k on the battery, I'd say it's way past time to change it out. You don't want to get stranded.
Most of us who have replaced the factory batteries have Optima redtops. You should be able to find 1 for under $125 with tax.
Old Aug 22, 2005 | 11:26 PM
Probably the battery is getting weak. You can have it checked and see what the result is.
Old Aug 22, 2005 | 11:36 PM
jrose7004's Avatar
jrose7004
I'd have it tested at the auto parts store then I'd get an Optima Red Top!
Old Aug 22, 2005 | 11:38 PM
Rage@AutoBuffs's Avatar
0Rage@AutoBuffs
Former Vendor
St. Jude Donor '10
Mine died Sat, thanks wally world!
Old Aug 23, 2005 | 01:18 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Take a look at your DTC Codes that are storred in the DIC Here is how:
This is the absolute best C5 Code web site!!!
http://www.corvettedoctor.com/Codes_Page.htm
If you have a ton of "U" series codes (i.e. U 1040, U1160, U 1064 ect) , your battery is most likely on it's way out! If you have a marginal battery it can cause your FOBs to constantly loose sync, memory settings to reset and a lot of strange electrical issues. Reset all of the codes and after a few days recheck them. If they come back, I bet the battery is at fault.
BC
Old Aug 23, 2005 | 02:14 AM
SLPRC5's Avatar
SLPRC5
Optima Red Top!
Old Aug 23, 2005 | 09:34 AM
Yoggi's Avatar
Yoggi
Old Aug 23, 2005 | 10:24 AM
rws.1's Avatar
rws.1
Get it load tested . depending on how much it sits, it could be that it the plates are getting coated with sulphates. This is a natural by product of electrolysis that happens as a lead acid battery sits without a charge flowing though it. The only effective way to prevent this and maximize battery life is with a battery float charger.
These devices are a 21st century battery charger. The microchip assesses the current drain or leakage and exactly matches the loss . This keeps your battery always fully charged without the risk of overcharging and prevents sulphate formation.
I bought mine at harbor freight ...
www.harborfreight.com
do a search on float charger
Old Aug 23, 2005 | 03:09 PM
MTurnbo's Avatar
MTurnbo
Make sure before you put in the new battery that you pull the battery tray (4 easy bolts) and check underneath to make sure there is no acid damage. While you're there you can use some baking soda to neutralize and touch paint.
Old Aug 23, 2005 | 03:17 PM
tmcclaff's Avatar
tmcclaff
St. Jude Donor '04 & '05
BC
That site doesn't seem to work!
Old Aug 23, 2005 | 07:35 PM
Neeko's Avatar
Neeko
thanks guys, i'll be purchasing my Optima Redtop this weekend. Anything i should know before installing this badboy?
Old Aug 23, 2005 | 07:45 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Yeah - don't drop the wrench into the "black hole" underneath the battery!
To battery going?
