Remeasured car...
Old Aug 29, 2005 | 10:07 PM
vett_girl's Avatar
vett_girl
Default Remeasured car...
Measured the car tonite, and after 5 days, the rear was 27 1/2" - now it's 27" The front was 26 3/4" & is still the same - no change. The front still needs to come down some, any suggestions??
The front was 27 1/2" before lowering, & the rear was 28 3/4" Used the stock bolts.
Old Aug 29, 2005 | 10:13 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
If the front bolts were just adjusted... then cut the bushings..
steve
Old Aug 30, 2005 | 01:56 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
steve
Old Aug 30, 2005 | 07:32 AM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
steve
And finally, if that isn't low enough then go get yourself some coilovers.
Old Aug 30, 2005 | 08:08 AM
vett_girl's Avatar
vett_girl
And where can I get those at??
Old Aug 30, 2005 | 08:15 AM
Pro Street's Avatar
Pro Street
my car on the stock bolts was
front 27.5 now 27
rear 29 now 28
My car is a 2002 with 7850 miles with the base susp.
Old Aug 30, 2005 | 08:50 AM
oaks99's Avatar
oaks99
need pics
Old Aug 30, 2005 | 08:51 AM
oaks99's Avatar
oaks99
need pics
Old Aug 30, 2005 | 04:13 PM
vett_girl's Avatar
vett_girl
K... here's a pic. The front bushings have been cut - It still measures the same almost a week later 26 3/4" The rear dropped 1/2 " already.
What's my options?? I want this the same size as the back. Thanks!
Old Aug 30, 2005 | 04:48 PM
TLKSCHP's Avatar
TLKSCHP
Are you sure their cut? I dropped mine the same day you did and I measure 26 3/4 front and 27 3/4 back and I didn't cut anything. The odd thing is that the passenger side is an 1/8 inch higher
Old Aug 30, 2005 | 05:12 PM
allaboutdaz's Avatar
allaboutdaz
anymore pics?
Old Aug 30, 2005 | 06:43 PM
jaxgator's Avatar
jaxgator
St. Jude Donor '07
Here's a couple sets:
http://www.lgmotorsports.com/shop/pr...5e5725ea60b2b4
http://www.dougrippie.com/drm/suspension_components.htm
I am sure there there are plenty others out there but you get the idea.
Maybe one of you has a Z51 suspension? Or something is different about your suspension? Maybe one of you has aftermarket shocks? Just guessing on my part.
Old Aug 30, 2005 | 06:46 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Remove the fronts bolts altogether
Old Aug 30, 2005 | 06:56 PM
DPG's Avatar
DPG
St. Jude Donor '06
you just cant remove the front bolts can you?
Old Aug 30, 2005 | 08:03 PM
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
I think you missed Glenn's big grin
Old Aug 30, 2005 | 08:18 PM
vett_girl's Avatar
vett_girl
Geezzzzzzzzzzz......... what's a girl gotta do to get help on here???
Thanks for the replys.
Old Aug 30, 2005 | 09:15 PM
Glennm27's Avatar
Glennm27
I was not kidding.
Read more HERE<====
To Remeasured car...
Old Aug 30, 2005 | 09:35 PM
FixedRoof's Avatar
FixedRoof
Yes you can.... In fact I have... and so have others...
Need to change out the stock shocks though... read that thread...
Old Aug 30, 2005 | 09:55 PM
DPG's Avatar
DPG
St. Jude Donor '06
So you just take the bolt out and then what, is that it. Besides getting new shocks(do you think I would be fine on stock Z shocks).
Old Aug 30, 2005 | 10:18 PM
FixedRoof's Avatar
FixedRoof
Take the bolt out... then get you a thin piece of rubber pad or something to put between the spring and the a-arm.. This keeps you from getting any noise from the spring rubbing on the A-arm.. And yes it's lower than just the cut bushings..
Stock Z shocks won't cut it in my opinion.. Get some Bilstein Sports.. They are designed for a lowered car..
steve
