as you can see, i'm a newbie to this forum. i've recently sold my turbocharged acura rsx-s (345 whp, 226wtq haha). i'm looking to move on and go back to american muscle.
my dilemma is the following:
should i pay the extra money for a c5 z06 or should i go for the regular c5 and go for a cam and bolt on setup (i/h/e)? what is your advice here? i am sick of modifying my cars- but i get the weird feeling i'm going to supercharge any vette i end up buying. as far as straight line speed goes what are your recommendations?
It depends on what you want. You'll probably mod the Z06, too....but it takes less money to get the same/better results. I wanted the Z06, but had to have the removable top of the coupe....so I bought the coupe and modified it to the performance level I wanted.
The Z06 is the better car, but if you are seriously modding you'll end up replacing most of the stuff you paid extra for in the first place.... and you make sacrifices you may not want since for C5s they are actual different body styles (I prefer the more aerodynamic hatchback, mag rid, and removable top). If the Z06 had an aluminum chassis seperating it from the fastback like on the C6, then that'd be another matter... but IMO go with whichever you can get the best deal on.
should i pay the extra money for a c5 z06 or should i go for the regular c6 and go for a cam and bolt on setup (i/h/e)? what is your advice here? i am sick of modifying my cars- but i get the weird feeling i'm going to supercharge any vette i end up buying. as far as straight line speed goes what are your recommendations?
thanks in advance!
meek
Im a bit confused... you say in your title, a c5 or a z06... but in your text you say c6 or a Z06... if the 2nd is true(c6/z06)... you know what to do... Z06 all the way... if the first (c5/z06)..
If you're going to mod anyway, then you have to think of what you like best... obviously you have less modding to do on the Z06.. but if you don't like the FRC.. or if you just like the Targa better... then go with the Coupe
Also, you have to look at color options... with the Z06, your only options are Torch Red, Electron Blue, yellow, silver, black, and a few 01 Whites still available... I personally like the Electron Blue Z06 (obvious bias!):
To me... some of the creature comforts that GM got rid of in the Z06.. **** me off... the dual electric seats, the good sport seats, the little gas cap holder!!?!? I don't know what that was about!! (CHEAP BASTARDS GM!!):
For the most in fun factor, go topless! Get an C5 M6 convertable, do a good cam/heads package with headers and gears and your done! Put the "abs of steel" plate while your at it and reduce your chassis flex and insulate better too. Go for the '01 and newer to get the stronger rod bolts and better intake.
Nothin like dropin the top and listenin to the rumpetta rumpetta of a good cam at the stop light.
Mine is a LPE 427 - and it's a blast.
If you are thinking about a C6 Z06, get in line now and you may get a '07 - or - pay the stealership an additional 10-15k over MSRP for an '06, IF you can find one.
I choose the C5 Coupe because I it is a summer car and the roof needed to come off. I did all the necessary MODS to make my car more competitive than a stock Z06.
If all you are concerned about is straight line speed, then I would go with the Z06. I look at it this way., in terms of starting platforms
With A Z06 you are starting with about 350RWHP (405 at the flywheel) The Z06 tranny has a more agressive set up and gearing, and stronger clutch, it's also a bit lighter than the coupe. If you ever decide to Autocross, you will already have a high performance suspension that comes with the Z, that you won't necessary get with a coupe
With a Coupe 6 Speed you are starting at about 300RWHP give or take (350HP Flywheel), it is cool to be able to remove the top, and if that is important than it might be a compromise for you to start out with 55 less HP.
These are just a few things to consider.
Good luck and welcome to Corvetteland
BTW- I have a coupe because I love being able to remove the top
