Active Handling without Traction Control
Aug 30, 2005 | 09:27 PM
When I hit the switch for active handling and traction control their is no option to choose one or the other. Does Active handling and Traction control work together, and cannot be disabled one at a time?
Aug 30, 2005 | 09:30 PM
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Press and hold the button for 10 seconds, Competition Mode is enabled.
In Competition Mode, TC is OFF but AH is still on.
Roast Rubber
Aug 30, 2005 | 09:32 PM
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
You want Competitive Driving mode.
Aug 30, 2005 | 09:57 PM
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
My question is are you sure that you have Active Handling? It was an option in 99, and the button looks the same whether you have AH/TC or just TC. Do you have RPO code JL4 on the sticker?
Aug 30, 2005 | 10:03 PM
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Sounds like you only have TC
Aug 30, 2005 | 10:37 PM
Aug 30, 2005 | 10:41 PM
Cruise-In VI Veteran
Yeah, if you have the JL4 code on the sticker in your glovebox, then you got it..
Also being a pre-2001 model, you will need to be completely stopped, then hold the button down to enter competitive mode. You cant do it when moving..
steve
Aug 30, 2005 | 10:48 PM
Does it stay in competative mode, or do I have to enable it everytime I start the car?
Aug 30, 2005 | 10:52 PM
it will reset when the key is turned off.. or you push the button..
It will always default to the normal setting..
Aug 30, 2005 | 10:55 PM
