Door lock Question
Old Aug 31, 2005 | 12:27 PM
Mac78and2K's Avatar
Mac78and2K
Default Door lock Question
Passanger side door lock works some times and not others. Seems to always lock, but does not always open/release when I push the switch on the door or use the fob. I am sure it is not a switch or power issue. Is there a selionoid that needs to be replaced?
Old Aug 31, 2005 | 01:40 PM
rws.1's Avatar
rws.1
Mine gives both intermittent lock and unlock.
I think there is a module in the door that is a common problem.
Old Aug 31, 2005 | 01:42 PM
rws.1's Avatar
rws.1
here's the thread I remembered...
http://forums.corvetteforum.com/show...ule&forum_id=1
Old Aug 31, 2005 | 01:43 PM
IDM's Avatar
IDM
It's most likely the actuator also called the door latch assembly I think.
The way to test it is to remove the connector and put a test light in it and hit the lock/unlock to make sure there's power going there.
I should recieve the part to replace mine tomorrow and at the same time get an alarm installed.
To Door lock Question
