How many Quarts Survey
Old Aug 31, 2005 | 07:09 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Default How many Quarts Survey
Ok because this came up in another thread I would like to take a survey to see how many quarts your car takes with an oil change including the filter.
Mine take about 6.9 quart. I put 1/2 quart in the filter and 6 more in the top then run the car. Usually I have to add some more once I check the oil again....
Old Aug 31, 2005 | 07:12 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
6 ½
Old Aug 31, 2005 | 07:15 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Just over 6 (probably 6 1/4)
Old Aug 31, 2005 | 08:27 PM
chaase's Avatar
chaase
St. Jude Donor '12
The two times that I have changed the oil, the car took 7 quarts...It wasn't full at 6.5, so the rest of the quart goes in
Chris
Old Aug 31, 2005 | 08:39 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
7 qts here.
Old Aug 31, 2005 | 08:40 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
I heard this before but I have not confirmed it.
A lot of dip sticks have a full and add line, but we just have the cross hatch area. I heard that full is considered in the middle of these hatch marks. If you try to get it to the top of the hatch marks it is almost 7 quarts with filter change.
Old Aug 31, 2005 | 08:45 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Just changed mine yesterday. Filled filter up and put the rest of the 6 1/2 qts in. Checked this morning and it was below the top line. Added the other 1/2 qt.
Old Aug 31, 2005 | 08:51 PM
1KLRTOY's Avatar
1KLRTOY
Originally Posted by Y2Kvert4me
7 qts here.
Old Aug 31, 2005 | 08:58 PM
JWB ZO6's Avatar
JWB ZO6
St. Jude Donor '06-'07
63/4 here
Old Aug 31, 2005 | 08:59 PM
JWB ZO6's Avatar
JWB ZO6
6 3/4 here
Old Aug 31, 2005 | 09:03 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
Originally Posted by Glennm27
6 ½
...and I throw the rest of the bottle in the trunk for later...
Old Aug 31, 2005 | 09:10 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
7 qts here.
Same here
Old Aug 31, 2005 | 09:48 PM
chocoholic's Avatar
chocoholic
How much it "takes" and how much oil you "need" for an oil change are two different things.
You need 6.5 quarts for an oil change. The hashmarks on the dipstick are the operating range. When you fill the car after an oil change, you want the oil level in the middle of that area. It's that simple. (p.s. the owner's manual is your friend)
Old Aug 31, 2005 | 11:15 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
7 feels so goooooooood...
Old Aug 31, 2005 | 11:41 PM
Dave68's Avatar
Dave68
Back a while ago, a CF member confirmed with GM that 6.5 is the correct amount of oil to add after a drain. Apparently, the correct way to read the dip stick is not conventional and 6.5 quarts will appear to be insufficient. Don't let the dip stick fool you. You are actually overfilling slightly if you add 7 quarts to get the oil line to reach the "FULL" mark.
Old Aug 31, 2005 | 11:45 PM
6.5 and it reads full.
Old Aug 31, 2005 | 11:56 PM
jrose7004's Avatar
jrose7004
6.5!
To How many Quarts Survey
Old Sep 1, 2005 | 12:00 AM
GrayC5's Avatar
GrayC5
Following is what the 2003 GM Service Manual has to say about this.
2003 GM Service Manual, page 6-195 (excerpt from Engine Oil and Oil Filter Replacement > Installation Procedure):
6. Fill the engine with the approximate amount and type of oil. Refer to Capacities - Approximate Fluid on page 0-36 and Fluid and Lubricant Recommendations on page 0-36 in Maintenance and Lubrications.
7. Run the engine for 3 minutes.
8. Raise the vehicle.
9. Thoroughly inspect the oil filter and oil pan drain plug area for leaks.
10. Allow the engine to cool for a minimum of 3 minutes.
11. Lower the vehicle.
12. Check the engine oil level.
13. Top-off the engine oil to the full mark on the oil level indicator (dipstick), if necessary.
Both the owner's manual and GM Service Manual say the approximate capacity is 6.5 quarts with filter. However, much will depend on how well the system was drained when removing the old oil. Usually, I end up adding around 6.8 quarts to stay just under the top dip stick full mark when changing my oil.
The cross-hatched area shows the proper operating range for your engine oil level. It should be above the bottom of the crossed-hatch, but not above the top of the crossed-hatch. Your owner's manual should speak more to this in Section 5, Service and Appearance Care > When to Add Engine Oil.
Old Sep 1, 2005 | 06:53 AM
WKMCD's Avatar
WKMCD
6 ½
Old Sep 1, 2005 | 07:32 AM
Wicked Weasel
Wow it looks like a 50/50 split for those that fill 6.5 and those that fill a bit more.
Thanks to everyone for answering the question.
