is there a trick to......
Old Sep 1, 2005 | 06:49 PM
GKrenn's Avatar
GKrenn
Default is there a trick to......
Is there a trick to getting the headlight housing to raise if the manual **** doesn't make it come up. I installed the bronze gears about 8 months ago with no problems and now the drivers side headlight doesn't come up. It appears to try but is'nt able to make it. When I turn the manual **** (counterclockwise) per the shop manual nothing happens. The passenger side manual **** works fine. Has anyone had issues with the bronze gears?
Old Sep 1, 2005 | 08:57 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Yes here is a pic of the ****, that is a cover, you must remove the cover and turn the screw.
Old Sep 2, 2005 | 08:07 PM
GKrenn's Avatar
GKrenn
Thats the problem, when I turn the **** counterclockwise the light does not come up. No matter how many times I turn it. The passenger side functions fine.
Old Sep 2, 2005 | 08:39 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Any noises or resistance? Perhaps something inside has come undone?
To is there a trick to......
