anyone else have this problem or solution
Old Sep 7, 2005 | 08:38 PM
STEEL's Avatar
STEEL
Default anyone else have this problem or solution
I replaced the front skid bar I think that’s what its called, and anyway i ordered a new one from genes kar shop. I was told it was from GM new and when I got it was bare metal and didn’t have the threads that are on the old one to hold the horn and plastic front piece to direct air to the radiator. So I decided to weld the old ones in its place. I used JB weld in the paste form and it worked for a long time but my car is lowered and the plastic piece takes a beating on every bump. I was driving one day and hit a bump and the weld came out and I was dragging the plastic piece for awhile and had to duct tape it so I could get to work. I ended up using the same weld stuff because I had it as a quick fix but I know it will happen down the road again, and am looking for a permanent solution.
Old Sep 7, 2005 | 10:21 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Plate savers
Old Sep 7, 2005 | 10:23 PM
red97vette's Avatar
red97vette
Originally Posted by screw991le
and at $50 we defidently know they're for the corvette! yay..always gettin screwed....
Old Sep 7, 2005 | 11:36 PM
Patches's Avatar
Patches
The threaded inserts are supposed to be installed at the time of installation. What I've done was to push the insert into the hole in the bar and then use the screw to partially collapse it in the bar and anchor it in. Then when you fully tighten it when you install the skid bar, the screw will pull the insert the rest of the way into it's permanent, anchored position. As you tighten the screw, you can feel when the insert is fully seated and then you can finish tightening the screw.
Old Sep 8, 2005 | 01:06 AM
poolhustler's Avatar
poolhustler
The main part of the plate saver looks pretty thick, but the two brackets on them are pretty flimsy?!??!?! Do they hold up??
Russ...
Old Sep 8, 2005 | 01:22 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Oh but they are GOLD PLATED!! Oh wait, that's just CHEAP CADMIUM!!!
Old Sep 8, 2005 | 07:33 AM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
What? I thought we're getting a deal because the write-up says, "These plates are available for less than half the cost of GM units and offer full protection!"
To anyone else have this problem or solution
