Fender Rub
Old Sep 9, 2005 | 02:25 PM
WDLSV C5's Avatar
WDLSV C5
Default Fender Rub
Hey I know its most likely been asked here before but here goes. When I turn to the left in a parking lot while in motion I hear what seems to be a tire rubbing someplace. It sounds like the right front. I've check and cannot find any place that looks like its rubbing. The vette is a 2004 and completely stock. Is this a common thing with this car? Thanks for any help.
Old Sep 9, 2005 | 03:08 PM
jrose7004's Avatar
jrose7004
Mine doesn't rub but I can only get in to my driveway and not scrape the nose when I turn to the right!
Old Sep 9, 2005 | 03:19 PM
DJD Z06's Avatar
DJD Z06
The wheels most definitely should not rub during a turn. Are you running stock wheels and tires?
Old Sep 9, 2005 | 03:29 PM
tiojames's Avatar
tiojames
Default wheel rub
I think what you are are hearing is tire scrub on the pavement. Slow full lock turns usually make one tire scrub. Both my Excursion and my Trans-Am did the same thing. Haven't made any full lock turns with the Vette yet.
Old Sep 10, 2005 | 03:05 AM
DJMRTS's Avatar
DJMRTS
See if your brake lines are rubbing the wheel or tire on extreme steering positions, espeacially if you have the steel-braded type.
Old Sep 10, 2005 | 07:18 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Are you sure it's tire rub? My guess is that it's really your front spoiler rubbing the driveway surface... The rub like crazy on nearly any slope and sound horrible... My guess is when you turn left into this particular drive it is because you approach it straight on and then you hear the rub?? When you leave, you turn right and it is more gradual and it doesn't rub because of the angle...
Have someone watch while you drive in this driveway if you can and go slowly, watch the rubber spoiler down under the front and see if it rubs the pavement... BINGO!!!
"Ayre.. There's your rub!" (Pirate speaking!)
Of course, I could be all wet!!!
Old Sep 10, 2005 | 08:15 AM
YO-EL's Avatar
YO-EL
Its the leaf spring...
Over time they lose their ability to hold the arch...
Replace it... front..
When you hear the scraping when going over dips or bumps from the rear, then its the rear's turn to be replaced..
Trust me on this..
Old Sep 10, 2005 | 08:39 AM
chocoholic's Avatar
chocoholic
If it's happening when you are on flat ground, and sounds like tyre noise with grinding overtones, it may be a brake duct. This is especially likely if it only happens on one side and only on full lock.
If you look under the car you'll see that there are locating lugs for the brake ducts that slot into the wheel well. Not only that, but the ducts need to be positioned in the correct orientation so as not to rub. you probably just need to reseat the brake duct.
By the way, just to clear things up, the phrase vroom is alluding to is actually from Hamlet's Soliloquy. Hamlet was the Prince Of Denmark.
To be, or not to be: that is the question:
Whether 'tis nobler in the mind to suffer
The slings and arrows of outrageous fortune,
Or to take arms against a sea of troubles,
And by opposing end them? To die: to sleep;
No more; and by a sleep to say we end
The heart-ache and the thousand natural shocks
That flesh is heir to, 'tis a consummation
Devoutly to be wish'd. To die, to sleep;
To sleep: perchance to dream: ay, there's the rub;
For in that sleep of death what dreams may come
When we have shuffled off this mortal coil,
Must give us pause: there's the respect
That makes calamity of so long life;
For who would bear the whips and scorns of time,
The oppressor's wrong, the proud man's contumely,
The pangs of despised love, the law's delay,
The insolence of office and the spurns
That patient merit of the unworthy takes,
When he himself might his quietus make
With a bare bodkin? who would fardels bear,
To grunt and sweat under a weary life,
But that the dread of something after death,
The undiscover'd country from whose bourn
No traveller returns, puzzles the will
And makes us rather bear those ills we have
Than fly to others that we know not of?
Thus conscience does make cowards of us all;
And thus the native hue of resolution
Is sicklied o'er with the pale cast of thought,
And enterprises of great pith and moment
With this regard their currents turn awry,
And lose the name of action.--Soft you now!
The fair Ophelia! Nymph, in thy orisons
Be all my sins remember'd.
Old Sep 10, 2005 | 08:43 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Wow.. and all this time I thought it was a pirate thing... Dang... Thanks for the English/Danish(?) lesson!! Cool!
Old Sep 10, 2005 | 08:48 AM
VetteSiNz's Avatar
VetteSiNz
I believe it's your front sway bar. Check all the bolts and nut...re-torque if needed.
To Fender Rub
