Filter Cleaner ???
Old Sep 9, 2005 | 08:24 PM
dezcapt51's Avatar
dezcapt51
Default Filter Cleaner ???
What is a good product for cleaning my stinger air filter?
Old Sep 9, 2005 | 09:01 PM
EatRice's Avatar
EatRice
I use K&N filter charger kit. Which includes a cleaner and oil. I have used it on all kinds of reuasble air filters.
Old Sep 9, 2005 | 11:09 PM
ljthe2nd's Avatar
ljthe2nd
I'll second that, but if your filter is blue, Mr Gasket makes the same type of kit for their "Cool Blue" filters it contains the same stuff as the K & N kit, except the oil doesn't have a redish color to it, it is blue, I know you can buy the "Cool Blue" recharge kit at Summit Racing, I've purchased it there before.
Old Sep 9, 2005 | 11:42 PM
Dave68's Avatar
Dave68
For the blue "Remay" filter, Jim Hall recommends Simple Green, although the K&N cleaner may be okay (not sure about that). Make sure you remove the saturated Simple Green with LOW pressure water from the inside out. Allow as long as is necessary for it to dry before oiling. After oiling (K&N filter-charger oil is fine), let it sit on paper towels so that any excess oil can drain out.
Old Sep 10, 2005 | 01:10 AM
jrose7004's Avatar
jrose7004
On my K&N I use Simple Green and recharge with a mixure of mineral oil and alcohol!
Old Sep 11, 2005 | 01:01 PM
dezcapt51's Avatar
dezcapt51
Thanks guys
To Filter Cleaner ???
