Height after lowering...
Old Sep 13, 2005 | 10:27 PM
vett_girl's Avatar
vett_girl
Originally Posted by vette217
I feel I got ripped off, lowered a 2 weeks ago and mine are 27 front and 28 rear on stock bolts no cutting. Does it need to settle more?
Did you measure before?? Mine settled in about 5 days with 130 mile road trip. If your not happy, go back - that's what I did, the guy took the front bolts out - all good now
VG
Old Sep 14, 2005 | 12:08 AM
Chicago's Avatar
Chicago
St. Jude Donor '15
Front 26 1/2 lowered on stock bolts no cutting
Rear 27/3/8 installed new grade 8 7" bolts
Old Sep 14, 2005 | 12:21 AM
mwagne16's Avatar
mwagne16
26-1/2 Front
27-1/2 Rear
All stock hardware.
Old Sep 14, 2005 | 03:37 AM
DJMRTS's Avatar
DJMRTS
It probably does, but not much maybe a 1/4" more or so in the front. You should be able to get lower than 27" in the rear with stock bolts. Tire/ rim combinations will also dictate the ride hight as well.
Old Sep 14, 2005 | 03:43 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Here is a different way to view the hieght, the bottom of myca car (under the door rocker paneling) it is about 4 inches off the ground. Maybe a little higher!
Old Sep 14, 2005 | 05:44 PM
vette217's Avatar
vette217
Well I did the job myself and the fronts are all the way up...no threads. The rear were left with 2 threads showing.
Old Sep 15, 2005 | 02:17 PM
LarryW's Avatar
LarryW
Stupid question for all of you:
If I lower mine all the way on the stock bolts, and let's assume that I get a full 1" drop; does this mean that the front air dam will be 1" closer to the road?
It's a PITA getting into/out of my driveway as it is now stock, without scraping the @hit out of that damn thing but I'm getting tired of the 4x4 look too
Thanks!!
Old Sep 15, 2005 | 03:33 PM
MY1STPEWTER's Avatar
MY1STPEWTER
That's about the same as mine. Do you have the Z51 package. That's what I have and they don't drop as much on stock bolts as the others.
Old Sep 15, 2005 | 03:35 PM
LiquidDI's Avatar
LiquidDI
Thanks!!
yes it will be 1 inch closer. My air dam scrapes everywhere but the car looks 10x's better. I've yet to actually scrape anything on the car though.
