Chrome Alternator & Bracket Help
If so, I think that's way above the capicity of little ole me.
Can anyone help with some tips.
I get a little nervous doing stuff to the vette alone, just seems like company helps.
Joe
send a PM, if interested
The power steering pulley has to removed with the correct puller to get the bracket off. The ABS brake modulator does have to be removed
Recalling EG's cam swap pics...he had the entire front of the engine stripped down to the bare block, but the brake module was still there, connected, in the pic. How did he do it? (asking because I;m in for this task myself soon).
EG?
And it is not difficult. You just need patience.
The power steering pump does need to be removed and pushed to one side. There is no need to disconnect any of the PS hoses and be careful not to tip the resevoir over.
The alternator bracket itself is fastened with either 3 or 4 bolts (13mm).
Start by disconnecting your battery, and then releasing your serpentine belt - just push the pulley on the passenger side and remove the belt.
Then remove your old alternator. Long bolt on top and bottom, and power wires on the back. Move it out of the engine bay.
Now remove the bolts holding the Power Steering pump to the engine block. This takes some patience because the bolts are not that easy to get to, but it is not difficult.
When you get the bolts for both the power steering and the alternator bracket out, just reverse your steps and you are done.
It sounds a lot harder than it is to do.
I guess about an hour if you have not worked under the hood before - 20 minutes or less if you have.
Hope this helps.
EG
That's a great bit of good news.
That is a whole different can of worms. The PS pulley almost always breaks when you try to remove that thing
I thought the poster was just doing his alternator and alternator bracket?
<edit> or is it all one bracket? I could have sworn it was two brackets when I did mine <edit>
Remove PS reservoir and lines
Remove ABS module
Remove PS pulley
Remove PS pump from alt bracket
Remove alt bracket.
The main difference is that you have removed the PS pump from the alt bracket w/o pulling the pulley. If you don't have to pull the pulley, you obviously don't have to remove the brake module...
Still no need to move the ABS module though.
I was under the impression the PS pump bolts-to-alt bracket were basically impossible to access and remove w/o pulling the pulley (that blocks access to those bolts).
You said they are tough to get to, but can be done. That makes a world of difference, and is the root of all the questioning here.
I will try and find a pic I took of the PS assembly.
