Railroad Vette
I thought you guys and gals would enjoy this photo I shot this morning after unloading my "speeder" onto the track at the SC Railroad Museum. We added extra ballast on top of the ties and I can just drive the Vette up onto the rails and then let it run along the rails far enough to center the trailer. Then I simply crank the "speeder" down onto the track and away I go.
At the end of the day, I pull the "speeder" up to the trailer, crank it on, tie it down, and away I go in my Railroad Vette.
We are using the "speeder" to reopen a section of track that is badly overgrown and in need of a lot of work. Here are some videos I shot of the "speeder" in action:
http://media.putfile.com/13Aug05-01
http://media.putfile.com/13Aug05-02
http://media.putfile.com/13Aug05-03
The speeder was moving at 10-15 mph. There is no suspension. You personally feel every track joint with your butt. The frame flexes when necessary. The noise is the steel wheels on the steel track. You can even here the small 2-cyl, 20 hp, Onan engine.
Then your next mod could be a flux capacitor....
But then his vette would only hit 88 mph..
Some of those trees growing up in the middle of the tracks.. whoa!! Looks like you could have used a small steam engine for weight to roll over some of them!!
Neat stuff!!
Thanks!!
A few other retirees and I are working to re-open 6.5 miles of track on the west end of the railroad to speeder operations. There are lots of photos with captions in the files section at: http://finance.groups.yahoo.com/grou...?yguid=1313337
As far as we can tell, the last time the original quarry railroad used the track on the west end was 40+ years ago and they had not been doing anything other than absolutely necessary maintenance for many years before that. The useful life of a railroad tie, under ideal conditions is considered to be 25 years, so the track is long over due for rebuilding.
We are first, clearing the brush and saplings and second, putting down weed killer and soil sterilizers.
As we need to, we are starting to replace individual ties here and there to keep the rails in gauge in the worst spots.
My light weight speeder does fine on this track but the heavier speeders and our track maintenance equipment is to heavy and spreads the rails. We are replacing ties the old fashioned way, by hand like they did 100 years ago.
Last weekend we took the big air compressor out and blew the packed red clay out of the flange-ways in one of the railroad crossings.
In the photo below, you see my speeder at the east end of the Chinese Wall. We have cleared about 1.4 miles of track to get there. There are so many saplings there that the speeder can not get through them so we are cutting them down with chain saws.
The work will get easier over the winter when the weather is cooler, the leaves are off the trees and saplings, and the Kudzu has died back.
what are you doing?
