Old 03-06-2015, 03:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
Print Wikipost
[Z06] C5 Z06 Frequently Asked Questions(FAQ)
Old 08-10-2005, 12:25 PM
  #41
LTC Z06
Get Some!
Support Corvetteforum!
LTC Z06's Avatar
Default All the C6 Z06 specs are here.
http://forums.corvetteforum.com/forumdisplay.php?f=100
Old 08-16-2005, 05:22 PM
  #42
LTC Z06
Get Some!
LTC Z06's Avatar
Default How to change pads and rotors, and other brake info.
How to change pads and rotors from chrisj:
Here are some links I bookmarked a while back on this topic.
http://forums.corvetteforum.com/show...post1552804278
http://forums.corvetteforum.com/sho...32&forum_id=103
http://forums.corvetteforum.com/sho...90&forum_id=103
http://forums.corvetteforum.com/sho...47&forum_id=103
http://dana60.com/rickko/corvette/rotor-rr.html
(the link that probably went with the picture posted above)
http://www.z06vette.com/forums/showthread.php?t=79451
(not sure if it's ok to post a link offsite - remove if necessary)
Good luck!
chris
and from UstaB-GS549:
You need 21mm socket and 18" breaker bar for bolts. Turn wheels full lock to get torque wrench and good leverage. 125 ft-lb.
I push pads back with a heel bar and remove calipers first. It's a 15mm bolt and you need a 16-18mm (can't remember) to hold flats on pin after you break bolt loose.
I think you are supposed to use Loctite 271 Red on bolts or get new ones, but I never do.
Slotted/drilled rotors: This one thread pretty much says it all.
http://forums.corvetteforum.com/show...85&forum_id=49
From AU N EGL
Why do high performance brakes squeal?
http://forums.corvetteforum.com/show...09&forum_id=49
Old 08-17-2005, 01:56 PM
  #43
LTC Z06
Get Some!
LTC Z06's Avatar
Default History of the Corvette name and symbol.
http://forums.corvetteforum.com/show...45&forum_id=74
History of the Corvette Emblem
Over the years, the Corvette has gone through many design changes; some subtle, some not so subtle. The Corvette's symbolic crossed flags emblem has also seen its fair number of changes. If you've taken a close look at the emblem over the five generations of Corvette, you'll notice that even though the design has changed dramatically from time to time, a few design cues remain. These include some form of a checkered flag and a bow-tie emblem. From time to time, a strange, maple leaf type of insignia, called a "fleur-de-lis" also shows up from time to time in the emblem. So what does all this mean and how did it get started?
The original Corvette logo (Figure 1) was designed by Robert Bartholomew, an interior designer at Chevrolet in 1953. This emblem was destined to appear on the 1953 Corvette prototype which was introduced to the public for the first time at New York's Waldorf-Astoria hotel in January of 1953. It had crossing staffs with the checkered flag on the right hand side, and the American flag on the left hand side. However, four days before the Corvette was to go on display at the show, Chevrolet management decided that it should be redesigned. The problem with the proposed emblem was that it included the American flag which is illegal to use on a commerical product. Right before the show, redesigned emblems were attached to the front hood and steering wheel of the Corvette. The new emblem contained the checkered flag on the right side as well as the white racing flag, red Chevrolet bow-tie symbol and a fleur-de-lis (Figure 2).
Where did the fleur-de-lis come from? At the time, Chevrolet was conducting research on various emblem designs for the 1953 and 1954 passenger cars. They looked at the Louis Chevrolet family history in an attempt to discover a crest or some type of heraldry that they could utilize. Unfortunately, they came up empty, but they did realize that Chevrolet is a French name and the fleur-de-lis (flower of the lily) is a French symbol meaning peace and purity. They decided to use the fleur-de-lis along with the famous blue Chevrolet bow tie on a new flag which replaced the American flag on the Corvette. When the 1953 Corvette first appeared to the public at the Waldorf Historia Hotel, the redesigned emblems were in place.
However, this emblem was temporary and used only for press photography at the show. A new emblem was designed prior to the 1953 Corvette going into production.
If you're wondering what ever happened to the original 1953 Corvette emblem by Robert Bartholemew, it's currently on display at the National Corvette Museum!
Old 08-21-2005, 01:09 PM
  #44
LTC Z06
Get Some!
LTC Z06's Avatar
Default Z06 and other wheel weights and sizes.
The thread:
http://forums.corvetteforum.com/show...33&forum_id=49
another good thread
http://forums.corvetteforum.com/show...06&forum_id=49
the other internet site
http://www.wheelweights.net/
Old 08-23-2005, 05:41 PM
  #45
LTC Z06
Get Some!
LTC Z06's Avatar
Default **Picture Tutorial** Helping YOU take better pictures of your C5
http://forums.corvetteforum.com/show...2&forum_id=103
Old 08-24-2005, 04:05 PM
  #46
LTC Z06
Get Some!
LTC Z06's Avatar
Default Me at the Nurburgring.
I'll post this vid elsewhere.
In the Green Hell and the "pucker" vid you have Mark, a.k.a 360Lemans doing the filming. Our friend and semi-pro driver Christe is in front in a Euro C5. In the green hell vid I'm already pulled over, and in the pucker vid that is the second carousel curve and I purposely left it early to see what would happen, that was a fun day!!!!!
Congaman at the 'Ring
http://forums.corvetteforum.com/show....php?t=1498086
A GT-2 ring run brought to use by member Waltk88:
http://www.edo-competition.net/movi...leife_gt2rs.wmv
A thread with some Nurburgring info and a link to the famous Hans BMW run!
http://www.bmwtransact.com/microsite/Nurburgring/
http://forums.corvetteforum.com/show...post1551858941
Z06 Ring article
http://www.supercars.net/Pics?vpf2=y...ID=1404211&l=d
First Z06 on a track.
http://forums.corvetteforum.com/show...1&forum_id=100
An awesome ring video!
http://forums.corvetteforum.com/show...48&forum_id=26
24 hour GT-3 vid with curve names
http://video.google.com/videoplay?do...68061834241022
Ben Lovejoy's Nurburgring website, it's the best!
http://www.nurburgring.org.uk/
Nurburgring threads:
http://forums.corvetteforum.com/show....php?t=1705082
http://www.supercars.net/PitLane?vie...ID=0&tID=10073
http://forums.corvetteforum.com/show...6&page=1&pp=20
http://forums.corvetteforum.com/show...g&forum_id=100
Old 09-07-2005, 03:32 PM
  #47
LTC Z06
Get Some!
LTC Z06's Avatar
Default Transmission service bulletin.
http://forums.corvetteforum.com/show...53&forum_id=49
Originally Posted by Michrider
Ask your dealer to look up PIP3020.
It tells to replace aluminum 3-4 shift fork with iron 3-4 shift fork.
Also replace 3-4 synchronizer and 3-4 blocking ring.
Old 09-10-2005, 02:23 PM
  #48
LTC Z06
Get Some!
LTC Z06's Avatar
Default Scratch or damage a wheel?
http://forums.corvetteforum.com/show...55&forum_id=49
Old 09-16-2005, 10:43 AM
  #49
LTC Z06
Get Some!
LTC Z06's Avatar
Default How to polish your Route 66 tips.
or similar aftermarket tips.
http://forums.corvetteforum.com/show...61&forum_id=74
Old 09-18-2005, 10:39 AM
  #50
LTC Z06
Get Some!
LTC Z06's Avatar
Default Is it Z oh 6 or Z zero 6?
http://forums.corvetteforum.com/show...post1552109104
Old 09-19-2005, 03:58 PM
  #51
LTC Z06
Get Some!
LTC Z06's Avatar
Default C6 Z06 brakes on a C5
http://forums.corvetteforum.com/show...3&forum_id=103
part II
http://forums.corvetteforum.com/show...7&forum_id=103
Old 09-20-2005, 06:36 AM
  #52
LTC Z06
Get Some!
LTC Z06's Avatar
Default Differential/axle seal leaks?
http://forums.corvetteforum.com/show...98&forum_id=49
Do a search for Differential or axle seal leaks in C5 General and you will get plenty to read.
Old 10-05-2005, 06:27 PM
  #53
LTC Z06
Get Some!
LTC Z06's Avatar
Default X or H pipe.
What do they do, does an aftermarket one make any difference? The best thread ever on this subject!
http://forums.corvetteforum.com/show...4&forum_id=101
Is Z06 exhaust louder than C5 stock? Yes!
http://forums.corvetteforum.com/show...71&forum_id=49
Old 10-06-2005, 04:51 PM
  #54
LTC Z06
Get Some!
LTC Z06's Avatar
Default How to polish your Ti exhaust tips.
Ti vs. Aftermarket HP difference?
Originally Posted by GTB/ZR-1
The sound is incredibly crisp & clean w/ headers & X-pipe--not to mention the Ti is lighter.
My tuner tested a 382ci Z06 w/ the factory Ti & Borla Stingers. The Stingers made 2.8 more RWHP--not worth the effort & headache on a modded motor--in my book...
http://forums.corvetteforum.com/show...02&forum_id=49
Use metal polish.
Also, the tips are chrome coated Ti.
http://forums.corvetteforum.com/show...46&forum_id=49
Thanks sshaddowz: Sorry it took so long. I could have worked longer on them to get a better shine and also if you work on them off of the car it will probably be alot easier. My digital cam started screwing up on me so they aren't as clear as i wanted. The last picture was taken old school with a 35mm slr. Hope they help.
Bryan
More tips:
http://forums.corvetteforum.com/show...post1553688402
Modified Ti mufflers!!
http://forums.corvetteforum.com/show....php?t=1401039
Old 10-07-2005, 11:59 PM
  #55
LTC Z06
Get Some!
LTC Z06's Avatar
Default How to distinguish between LS1 and LS6.
http://forums.corvetteforum.com/show...5&forum_id=103
Old 10-09-2005, 07:38 PM
  #56
LTC Z06
Get Some!
LTC Z06's Avatar
Default Is a Z06 just a C5 with bolt ons?
A good discussion.
http://forums.corvetteforum.com/show...68&forum_id=49
Old 10-12-2005, 04:14 PM
  #57
LTC Z06
Get Some!
LTC Z06's Avatar
More C6 Z06 brake pics.
To C5 Z06 Frequently Asked Questions(FAQ)
Old 10-12-2005, 04:15 PM
  #58
LTC Z06
Get Some!
LTC Z06's Avatar
and some more C6 Z06 brake pics
Old 12-14-2005, 01:58 PM
  #59
LTC Z06
Get Some!
LTC Z06's Avatar
Default iPOD your car.
A very good info thread.
http://forums.corvetteforum.com/show...856&forum_id=1
Old 12-16-2005, 11:21 AM
  #60
LTC Z06
Get Some!
LTC Z06's Avatar
Default Clear corner light install how to.
http://forums.corvetteforum.com/show...976&forum_id=1
Quick Reply: [Z06] C5 Z06 Frequently Asked Questions(FAQ)
