Quick Help Needed
Old Sep 19, 2005 | 03:30 AM
BickyDhadwal's Avatar
BickyDhadwal
Default Quick Help Needed
Hey everyone...i think the bulb just needs to be replaced but im not sure...my driver side turn signal is blinking super duper fast...the tail lights blink really fast...the front one doesn't blink but it stays on (for day time running lights)....i was going to replace the bulb...but how do i get to it????????
Old Sep 19, 2005 | 03:46 AM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
yeah, you need to replace the bulb, their is a plasctic access pannel that i removed to get to it from under the car, had the car up on ramps, im sure someone will give yo a better answer. I replaced my running lights with red bulbs, its subtle and looks cool. Good luck
Old Sep 19, 2005 | 05:44 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
You are correct, your bulb needs to be replaced. You have three choices for the swap. You can remove the panel under the nose, you can go in through the front brake duct inside the wheel well or you can raise the headlight and just work your arm down to the bulb socket. The third option is the one that I have used. It is a tight squeeze but I can just manage to get my arm in there.
Paul
Old Sep 19, 2005 | 09:48 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Paul is 100% correct!
Old Sep 19, 2005 | 05:14 PM
BickyDhadwal
thanks a bunch guys
Old Sep 19, 2005 | 05:18 PM
lickitydoo's Avatar
lickitydoo
You might want to remove the black bezel around the light also, makes it a little easier to get your arm in there. I had to in order to fit my arm in. A little KY might help you to slide you arm in also.
To Quick Help Needed
