VIN information
Old Sep 19, 2005 | 01:39 PM
sirsenna's Avatar
sirsenna
Default VIN information (ATTN SPONGE VETTE! see below)
Can someone verify the options on this vette?
1G1YY32G7W5107638
Looking at buying it, but would like to know all the options.
thanks
Denis
Old Sep 19, 2005 | 01:46 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I don't believe the VIN will get you all the options. The best place to find them is the RPO sticker on the inside of the glove compartment door. All the codes are listed there.
Old Sep 19, 2005 | 01:48 PM
sirsenna's Avatar
sirsenna
I did this before... when I bought my 98 coupe. someone on here gave me all the details on it, just with the VIN
thanks
d
Old Sep 19, 2005 | 02:11 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
1G1YY32G7W5107638
Looking at buying it, but would like to know all the options. thanks
Denis
VIN 1G1YY32G7W5107638
VEHICLE BUILD
Merchandising Model : 1YY67 -1998 CORVETTE CONVERTIBLE
Gross Vehicle Weight Rating : 1697 kg (3742 lb) Order Number : 9109E2
Build Date : 10/08/1997 Build Plant : 1W5Y - BOWLING GREEN
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY PASSENGER POWER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AR9 - LEATHER BUCKET SEATS
BGR - BOWLING GREEN PLANT B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C05 - CONVERTIBLE FOLDING ROOF DL5 - ROADSIDE SERVICE INFORMATION DECAL
DL8 - HEATED REARVIEW MIRRORS FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - FEDERAL EMISSIONS F45 - CONTINUOUSLY VARIABLE REAL TIME DAMPING
GU2 - REAR AXLE 2.73 RATIO IP3 - TRIM INTERIOR DESIGN - AR9
JL9 - 4-WHEEL ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI, V8 MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF2 - FEDERAL EMISSION SYSTEM, TIER 1
NK4 - LEATHER WRAPPED STEERING WHEEL QD4 - STYLED ALUMINUM WHEEL
T96 - FOG LAMPS UL0 - AM/FM STEREO CASSETTE RADIO
UZ6 - QUAD SPEAKER SYSTEM U1S - COMPACT DISC PLAYER, REMOTE
U52 - ELECTRONIC INSTRUMENTATION U75 - POWER RADIO ANTENNA
VM3 - CONSUMER INFORMATION LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR
1AY - STOCK ORDERS PROC OPTION 1SB - OPTION PACKAGE - BASE
13U - SILVER SEBRING METALLIC 41T - T0P-BLACK
92I - MED GRAY INTERIOR TRIM 923 - PEWTER LEATHER
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
08/11/2001 263520 # J6360 - MODULE, PCM/VCM - REPLACE 29096 miles
08/11/2001 263520 3 N2819 - RELAY - IGNITION SYSTEM - REPLACE 29096 miles
08/11/2001 263520 3 J5582 - MODULE, ELECTRONIC THROTTLE CONTROL - REPLACE 29096 miles
08/11/2001 263520 # T2020 - TOWING 29096 miles
08/10/2001 263450 3 N4800 - MODULE, COMPUTER (CONTROL) BODY - REPLACE 29091 miles
08/10/2001 263450 3 T2020 - TOWING 29091 miles
08/07/2001 263255 0 N2869 - RELAY - THEFT DETERRENT - REPLACE 29059 miles
08/07/2001 263255 # V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 29059 miles
09/20/2000 246096 # C6041 - ADJUSTER ASSEMBLY, FRONT SEAT POWER - BUCKET SEAT - DRIVER 26441 miles
04/03/2000 237369 # C7051 - COVER AND/OR PAD, FRONT SEAT BACK CUSHION - LEFT - R&R OR 24892 miles
09/02/1999 125951 # D1322 - MOTOR AND/OR FAN, BLOWER - A/C - R&R OR REPLACE 24042 miles
08/23/1999 125452 # J5582 - MODULE, ELECTRONIC THROTTLE CONTROL - REPLACE 23899 miles
08/23/1999 125452 # Z7903 - 3-DAY COURTESY TRANSPORTATION 23899 miles
06/18/1999 122197 # H2640 - PEDAL AND/OR BUSHING, BRAKE - R&R OR REPLACE 21563 miles
12/23/1998 113885 # R3011 - TRANSMITTER, KEYLESS ENTRY - REPLACE 17130 miles
12/23/1998 113885 # E3110 - SPRING, FRONT TRANSVERSE - REPLACE 17130 miles
10/12/1998 110342 # C0100 - GLASS, FRONT DOOR - RIGHT - ALIGN 13747 miles
08/14/1998 056771 # R3011 - TRANSMITTER, KEYLESS ENTRY - REPLACE 8892 miles
06/04/1998 054142 # R3012 - MODULE, KEYLESS ENTRY - REPLACE 8683 miles
06/04/1998 054142 # B4361 - ROD, FRONT DOOR INSIDE LOCKING - LEFT - R&R OR REPLACE 8683 miles
11/18/1997 047535 # B7350 - PANEL, AIR INLET GRILLE - CENTER OR ONE PIECE - REPLACE 866 miles
10/08/1997 A07638 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Old Sep 19, 2005 | 02:35 PM
sirsenna's Avatar
sirsenna
Sponge... you are the man!
thanks a bunch!
Denis
Old Sep 20, 2005 | 12:49 PM
sirsenna's Avatar
sirsenna
Default Attn Sponge!
Hey Sponge,
The last car i asked you to check didnt go through... title issues.
...but I did find another I'd love to pick up this coming weekend. Can you please check it out for me? (options, service, etc... like you did last time)
1G1YY22GX25103930
thanks a bunch
(I copied this message to your PM)
Denis
darsenault@pizzadelight.ca
Old Sep 20, 2005 | 01:08 PM
2vettes2go's Avatar
2vettes2go
don't know, but i think i'd leave this one alone. too many claims, wonder what is wrong with this vette. but if you do , good luck.
Old Sep 20, 2005 | 01:10 PM
sirsenna's Avatar
sirsenna
I did pass up on it... thanks partially to Sponge!
thanks
denis
Old Sep 20, 2005 | 01:20 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
thanks
denis
Sponge Vette has provided valuable information to owners and potential owners time and time again. A Great Forum Member.
Old Sep 20, 2005 | 02:32 PM
sirsenna's Avatar
sirsenna
You are right on that one.... he is a GREAT asset to this forum
Denis
To VIN information
