Help - A pillar trim removal
Old Sep 19, 2005 | 10:02 PM
Barry Hanna's Avatar
Barry Hanna
Default Help - A pillar trim removal
How do you remove the inside A pillar trim on the passenger side of a 2004 vert? I'm trying to run a power cord for my Valentine 1 and I don't want to damage the trim piece.
Old Sep 19, 2005 | 10:14 PM
Armadillo's Avatar
Armadillo
Grab hold of it and pull back and out. It comes off fairly easily.
Old Sep 19, 2005 | 10:19 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
actually didnt have to remove mine...
...just pulled back a little to snake the wire in and down the pillar...
Old Sep 20, 2005 | 01:45 AM
Vegas Vette's Avatar
Vegas Vette
Just give it a littel tug it should come right off. I just installed a Raptor Shift light on the drives side came out easly. Good luck.
Old Sep 20, 2005 | 01:58 AM
ericdwong's Avatar
ericdwong
I agree, but be sure to remove the friction fitting in the door jamb at the very lower part of the A pillar.
Also, sometimes you may need to cut some adhesive off the bottom where the weather strip meets the A pillar depending on sloppy the car was assembled in BG.
Old Sep 20, 2005 | 05:48 AM
DeeGee's Avatar
DeeGee
Old Sep 20, 2005 | 12:29 PM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Old Sep 20, 2005 | 02:09 PM
Lancer033's Avatar
Lancer033
I hate to say this, but that sounds like twice the work for a piece that just pops in and out
Old Sep 20, 2005 | 05:07 PM
HummelS's Avatar
HummelS
I just kinda poked it in there with a flat-blade screwdriver.
Old Sep 20, 2005 | 05:12 PM
2003vert's Avatar
2003vert
start at the top, get your finger nails under the plastic on both sides, ( If you don't chew your nails this will work ) if you are sitting in the seat apply even pressure toward you. It will just pop out.
Old Sep 20, 2005 | 05:46 PM
yankeevetteconvert's Avatar
yankeevetteconvert
Anybody know the part number for this piece? Mine needs to be replaced and if its that easy I will do it myself.
Old Sep 20, 2005 | 11:19 PM
DeeGee's Avatar
DeeGee
Not if you break a clip
Old Sep 21, 2005 | 10:46 AM
vetdude's Avatar
vetdude
Contact Gene at Fred Beans - has the # and the best price.
To Help - A pillar trim removal
