help . . . . exhaust plate ????
Old Sep 21, 2005 | 07:39 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I used 3M tape on mine.
Old Sep 21, 2005 | 07:44 AM
ZaydeZ06's Avatar
ZaydeZ06
thingies
Old Sep 21, 2005 | 07:54 AM
vermjpv's Avatar
vermjpv
Now a CTS-V Owner
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
Originally Posted by JDs00PewterCoupe
The double sided tape should work just fine. I've had mine on for four years and it is still stuck on there very well.
Old Sep 21, 2005 | 09:15 AM
BigJoe's Avatar
BigJoe
To those that are trying this for the first time here is a good method for getting them straight. https://www.corvetteforum.com/techti...=179&TopicID=1
May have to modify it a bit if you have a different type plate but the concept is the same. Oh, and as the others have said the tape that comes with the plate is more than strong enough to keep it in place until you want to remove it. (Removal is another topic. )
Old Sep 21, 2005 | 09:26 AM
JimmyZ06's Avatar
JimmyZ06
Stuck on and stuck good
Old Sep 21, 2005 | 09:41 AM
Jim2003's Avatar
Jim2003
I put the 50th flag plate on my car 2 years ago and 24k. I followed directions, cleaned the area carefully with alchol and then as the above posts say get it right the first time with a level cause it sticks hard and fast.
