St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
A question about the chrome caps for engine
I bought some chrome caps for my engine you know the ones that go on over the radiator cover, master cylinder and so on.Well the instructions tell you if they donot fit perfect to use masking tape to keep them on,is their a better way to do it like using 3m tape because to me masking tape would not keep them on.And where should the tape go along the sides or on the underneath of the cap and then stick it on. Thank you Charlene
The ones Ive had fit snuggly...
...but 3m tape is tacky enough to hold them in place...
Stop by an auto glass place, they have a rubbery, sticky adhesive material to hold windshields in. You can roll out a narrow bead of it, place it inside the chrome cap and then push the chrome cap onto the OEM cap, tight fit that won't pull off very easy. I keep the stuff in the garage all the time, almost like having duck tape around....
Originally Posted by stuart
the caps from Ecklers...
...the 3m tape from auto discounter...
The caps held by small amount of tape are easily removed for cleaning...
Ok thanks mine are from mid america and go for 97 to o4 vettes guess that is why they need some kind of tape on them to hold them on old story one size fits all hahaha.......char
I bought an extra set of caps from the dealer at a price less than what you see on the forum as a "package deal".
I used a cement/glue to hood them on the new set of caps and I switch the entire set out at the end of each season and clean and polish the chrome set.
