I own a 03 zo6 bought new in Feb 04 put on the road April o4. Seat easy entry only seems to work occasionally. Water gets in the door sills when it rains. Air conditioner on all the time even though exterior temp is colder than setting. What am I doing wrong
When exiting the car be sure you do not open the door before you remove your key. I believe if the door is opened first the seat will not move back. Was this your question?
Don't know about the air conditioning question but I am curious about the answer as I have a friend with the similar issue.
Read your owners book carefully and take your time. The C5 controls need to be done in the right order. Like, key in seat belt on where you have your memory settings on and on. Be patient, it can seem crazy...
