Does the performance exhaust systems make any performance difference?
Sep 28, 2005 | 08:04 PM
Do the aftermarket exhaust's re:Borla, Corsa, B&B make any performance difference? They claim a 10 to 15 HP increase over stock but does that really make the car faster or does it just sound faster?
Sep 28, 2005 | 08:16 PM
Cruise-In II Veteran
Cat-back exhaust are for sound only. Since the flow is limited by intake, opening up the mufflers won't increase HP.
Sep 28, 2005 | 08:17 PM
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Quote:
Roger that
Sep 28, 2005 | 08:20 PM
Quote:
Originally Posted by EnglandGreen
Roger that
Sound alone is worth it. Then when you add headers it just keeps getting better and better.
Sep 28, 2005 | 08:36 PM
St. Jude Donor '03-'26
After my Corsa's were installed, my mileage went to hell. I couldn't help stomping on it from red lights.
Sep 28, 2005 | 08:37 PM
St. Jude Donor '05, '12-'13, '15-'16, '21
Sep 28, 2005 | 11:21 PM
You can get anywhere from 5 - 20 hp increase depending on who you want to believe, but the sound hp increase is usually about 75 - 100 hp.
Sep 29, 2005 | 12:04 AM
St. Jude Donor '05-'07-'08-'09
I want my BB-PRT'S
Not a bad Idea!! I like that!!!
Sep 29, 2005 | 12:15 AM
So..... I DON'T have 400 HP now?
Sep 29, 2005 | 12:18 AM
You need to put a blower on there to cram more air in
Sep 29, 2005 | 07:11 AM
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Quote:
Nah... probably more like 409 if you have the exhaust plate.
Sep 29, 2005 | 08:03 AM
You get more HP from a hood seal.
Sep 29, 2005 | 12:05 PM
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
All I've done to my car is a Blackwing and a Corsa touring. I have a '97 which starts at 345 at the crank. If I subtract the drivetrain loss which is estimated at 14% for a mn6 I should have been at 296.7 stock at the rear wheels. I had my car dynoed last month and I pulled at 308.7 at the rear. I have a gain of 12 rwhp over my calculated rwhp (or 14.3 at the crank) I am betting the split is 85/15 for intake to exhaust.
Paul
Sep 29, 2005 | 12:12 PM
2026 Restomod of the Year Finalist
Quote:
Sep 29, 2005 | 02:20 PM
Quote:
I have one!! and a hood seal! I feel a lot better now, thanks for your technical input!!
