Door lock intermittent
Old Sep 30, 2005 | 09:34 PM
Mac78and2K's Avatar
Mac78and2K
Default Door lock intermittent
The pass side door lock works intermittenly. Is it the power door lock module I need to replace or is it something else?
Old Sep 30, 2005 | 11:30 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Old Oct 1, 2005 | 12:22 AM
DBRASUE's Avatar
DBRASUE
Hows the battery in your remote? Mine had problems such as yours until I replaced the remote battery.
Old Oct 1, 2005 | 07:24 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
This intermittent condition, is it with the remote or with the door switches? You could need a battery in the remote or you might have a loose connection at the wiring harness into the door. Of course it could also be the module but please provide more details on the problem.
Paul
Old Oct 1, 2005 | 08:02 AM
StevieB's Avatar
StevieB
It's the C5 gremlin. Ours sometimes will not go to correct settings for the seat and mirrors. It only happens to my wifes settings. I can have mine set at #1 or 2 and it works every time. It doesn't matter which one we set it for her it works intermittently. If she lifts her weight off the seat and sits back down, then it works. It's not like she is heavy or anything, maybe 130, and I'm a fatso 245. I figure it has to be in the wireing harness, but I'm not willing to go to a dealer and have it screwed op more than it is now. OH BTW my cruise control quit on me. It's no bid deal, because we only use the car around town, but still, these little things make me pissed that a mid $40s car has these little anoying things going on.
Old Oct 1, 2005 | 10:06 AM
Iceman_K's Avatar
Iceman_K
I had the exact same problem with the passenger side lock. I tried the things listed above with no improvement. So, I ordered a replacement door control module from Gene's Kar Shop (junkyard). Gene is a vendor on this site out of Florida. Two weeks ago I replaced the module and it has worked perfect ever since. New door control modules run around $200 but, you can find one at a junkyard for $50 - $100. Good luck and let us know if you solve the problem.
Old Oct 1, 2005 | 11:45 AM
DeeGee's Avatar
DeeGee
I had the door module replaced on the drivers side after it stopped working.
My passenger side started playing up recently. I reprogrammed the fob and it seems better now. I also find that the 2 clicks you need to open the pax door can be difficult to select sometimes. It needs 2 clicks almost simultaneously.
Old Oct 1, 2005 | 12:31 PM
Mac78and2K's Avatar
Mac78and2K
Thanks for the advice. I know it is getting a signal because I can hear it click on that side and if I assist the lock opening by gently pushing on it the lock will open. I am sure it is in the mechanism just don't know if it is the door module or the power window module, if they are actually different modules.
Old Oct 1, 2005 | 02:28 PM
DeeGee's Avatar
DeeGee
From my work ticket:
"12094 diag and found low voltage from door moduler to lock actuator on unlock circuit 294. Replaced left door module"
N4921 Module Local interface unit door left.
1 10342159 module $227.86
Don't know the part no for the RH module but should be similar.
Old Oct 1, 2005 | 02:39 PM
Mac78and2K's Avatar
Mac78and2K
Thanks for the info. The lock will always lock, but will usually not open. I can manually open it and it always will lock. Sound like a door module?
What is a good price for a nice used one. Heard some say $25-$50 and I see them on ebay for $20-30 and found one from a forum member for $75.
Old Oct 1, 2005 | 02:52 PM
DeeGee's Avatar
DeeGee
The symptoms sound just the same as I had. The module would be my bet. Can't help on the prices though.
Old Oct 1, 2005 | 03:00 PM
Mac78and2K's Avatar
Mac78and2K
I am beginning to agree. Anyone have the instructions for removing the passanger door panel so i can have access?
Old Oct 1, 2005 | 04:09 PM
DeeGee's Avatar
DeeGee
http://www.vetteessentials.com/instr...or_handle.html
Courtesy of Ken King at Vette Essentials
Old Oct 1, 2005 | 04:14 PM
Mac78and2K's Avatar
Mac78and2K
PERFECT...Thank you!!!
Old Oct 1, 2005 | 04:16 PM
DeeGee's Avatar
DeeGee
Old Oct 1, 2005 | 05:00 PM
Ms.NoUCant's Avatar
Ms.NoUCant
Navigator
My 04 was doing that also but the window was working intermittenly too! Turned out to be a loose connection inside the hose where the wires run from the car to the door.
Old Oct 1, 2005 | 06:22 PM
Antvette's Avatar
Antvette
Veteran: Marine Corps
Wow, I have the deal with mine. I have it under warranty but don't wanna mess with the dealer.
To Door lock intermittent
