Color Matching Help - Interior!
Old Oct 4, 2005 | 12:05 PM
UR LZN's Avatar
UR LZN
Default Color Matching Help - Interior!
I drive an ’03 Anniversary Coupe and just purchased an A-Pillar Gauge Pod for it. Of course, the Pod comes in black and the Corvette interior is Shale (per GM). The same color is used on the ’04 Commemorative Editions. The RPO codes on the glove box do not indicate interior paint colors – only exterior. Using the DuPont color chart pointed to a Pewter color. I purchased some paint and sprayed the part. The color is off – not enough brown in the mix – close but not close enough.
I’ll go back to my supplier for correction but I thought I’d pose the question:
Does anyone know the color codes for the interior colors on the ’03 Anniversary or ’04 Commemorative Editions? If I can get the actual codes, the paint mix should match.
Thanks for any help or recommendations…
Old Oct 4, 2005 | 12:10 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
RPO: 94U
DuPont Name: Anniversary Red Metallic Anniversary Red Pearl Metallic (Tintcoat)
WA#/Paint Code: WA-820K / GM-94
Stock#: P4727 / P4728
Old Oct 4, 2005 | 12:13 PM
MyVetteDream
RPO Name Dupont Name MFR Code Stock Number
154 Shale Shale 15 / 149B C9505
http://www.corvetteactioncenter.com/...2003paint.html
Old Oct 4, 2005 | 01:52 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Anyone know where to buy it
To Color Matching Help - Interior!
