CLB Hazards
Old Oct 7, 2005 | 12:48 PM
bozo4onion's Avatar
bozo4onion
Default CLB Hazards
Got the pull key message recently. Column unlocked uneventfully though. I ordered the CLB which will arrive from Vettes o' Houston on Mon. Now I read that the bypass doesn't necessarily solve the prob. and that the column may, indeed, lock WHILE DRIVING.....EVEN REAL FAST . Has anyone had this happen.
Old Oct 7, 2005 | 12:58 PM
LV_2_XLR8's Avatar
LV_2_XLR8
That's impossible, as the CLB disconnects the motor electrically.
Old Oct 7, 2005 | 01:03 PM
bozo4onion's Avatar
bozo4onion
I read that the pin can fall back down into the disk...???? Hoping this is some freaky worst case scenario thingie.
Old Oct 7, 2005 | 03:14 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
I've never heard of this and I believe it is phyically impossible with a proper install.
rr
Old Oct 7, 2005 | 03:21 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
The CLB makes the computer THINK the column is functioning normally.
Some early C5's (97,98) the bypass would not work, but for most I would say the CLB works fine....probably 98% if installed properly work fine.
Old Oct 7, 2005 | 04:03 PM
edensknight's Avatar
edensknight
I agree. Get the CLB. You are better off with it than without it. Be sure to clear your battery (disconnect to erase all trouble codes). Good luck to you.
Old Oct 7, 2005 | 05:48 PM
Had my CLB on for over a year now with no incidents of locking.
Old Oct 7, 2005 | 05:55 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
Maybe what you have read that after the dealer recall service has been performed the column can still lock.. THAT IS TRUE
With the CLB installed the column will NOT lock ever again.
That means never, even when you want it to, like when parked......
To CLB Hazards
