What's that growl when I start the car -99 Coupe
Old 10-07-2005, 08:46 PM
HJS815
HJS815's Avatar
Default What's that growl when I start the car -99 Coupe
What's that growl when I start the Car?
The noise happens when I start turning the steering wheel. Car is a 99 Coupe with 41000 miles on it. Seems to happen when the car is cold or already heated up. Power steering level is up to the mark. . . John
Old 10-07-2005, 08:50 PM
JCGRCYA
JCGRCYA's Avatar
St. Jude Donor '06
Is it a "growl" or more like a squeak. Mine was doing the same thing, I think, and I mentioned it when I had the car in for service. They said all they did was lube some part in the steering column or something and it went away. Later I found this tech tip (see link), which better describes what the dealership did. Hope it helps.
https://www.corvetteforum.com/techti...D=35&TopicID=1
Old 10-07-2005, 09:06 PM
HJS815
HJS815's Avatar
Sounds like a groan or grinding sound, not a squeek. Will look into the addition of lithium grease. Thanks
Old 10-07-2005, 10:45 PM
HERK
HERK's Avatar
its the tiger in your tank. sorry just had to.
Old 10-08-2005, 12:42 AM
vert99
vert99's Avatar
is the car a automatic? if so could be drive belt rumble.
Old 10-08-2005, 07:56 AM
RocketDawg
RocketDawg's Avatar
CI 6-7-8 Veteran
St. Jude Donor '09
I don't know what it is, but I've got the same thing. Seems to happen upon startup and with a slight turn of the steering wheel. It goes away after a few seconds, but you can feel it in the steering wheel and the engine rpm's decrease a bit. And, of course, it's intermittent.
Old 10-08-2005, 09:45 AM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
the air pump under the driver's side healight area kicks on to lower emmisions, cats light off quicker, this could be what your hearing; it is an electrical air pump and is no way related to any steering movements
Old 10-10-2005, 10:28 AM
HJS815
HJS815's Avatar
Thanks for responding to my efforts to find the groan/growl. You replied that the noise might be the sound of the cats firing. I have tried waiting a few moments before turning the steering wheel. It seems to be related to the turning of the wheel. What does a power steering pump sound like when it is about to fail? Problem occurs when the car is cold (morning sickness) and when the car is warmed up. I like your old job of working on my favorite aircraft (A-10). Thanks, John
To What's that growl when I start the car -99 Coupe
Quick Reply: What's that growl when I start the car -99 Coupe
