Camera mounting for autocross
Old Oct 8, 2005 | 08:22 AM
dr.nick2's Avatar
dr.nick2
Default Camera mounting for autocross
Who makes the best mounting system for a camera mount on the
interior of a C5???
Old Oct 8, 2005 | 09:01 AM
TedDBere's Avatar
TedDBere
Go to http://chasecam.com/ for all your needs.
Many people use a Hardbar to mount the camera to, but the suction cup mounts from ChaseCam produce some great shots! IMHO
Old Oct 8, 2005 | 09:05 AM
VetteSiNz's Avatar
VetteSiNz
http://www.stickypod.com/products.htm
Old Oct 8, 2005 | 10:03 AM
lost's Avatar
lost
Neither of the suction cup mounts will pass tech, at least not here in Houston.They made me me remove my carpets and center caps.Mine is the Woods Power Grip and uses a internal pump to create 70 lbs of suction, I've even used it to mounted to the exterior of the car at speeds up to 40mph without problems.
Old Oct 8, 2005 | 11:10 AM
dr.nick2's Avatar
dr.nick2
Default camera mounting for autocross,for "Lost"
Lost,thanks for the reply for Woods Power Grip,Question:what model #
is the 'grip' you use?
Old Oct 8, 2005 | 11:14 AM
TedDBere's Avatar
TedDBere
Here's my favorite video from a NE SCCA event. This is from a Chase Cam mount BTW: http://www.cpdserver.com/chasecam/vi...day%2056-7.mov
You'll need the newest Quicktime program to view it.
Old Oct 8, 2005 | 01:00 PM
lost's Avatar
lost
Mine is a 3028. anyway the differences are the levers that loosen or tighten the manfrotto head, as you can see on mine those levers are long and narrow and although location is totally adjustable by pushing the white button, they sometimes get in the way. The only other model I am aware of, has smaller x shaped levers, other than that they are identical.Mine was on sale for $90 the other wasn't.
Old Oct 8, 2005 | 05:33 PM
diyguy's Avatar
diyguy
I did a DIY one. Very inexpensive and solid as a rock. Absolutely NO jitter. Stick Pod's shake and get a resonance in them that can cause some un-impressive video..IMHO
SEE HERE FOR A DIY MODEL
Here's a vid showing how steady it is:
STEADY VIDEO...
To Camera mounting for autocross
