Bad Resonance
mwbmd11: Depends what you mean by resonance as many have different descriptions.
Personally, the only resonance I ever hear is when I first crank up the car when it is cold and only at idle. Soon as I put it in gear there is no resonance.
Now, if it's drone you are talking about, well I get some in 4th at around 45-50. Easy fix - I just put it in 3rd.
At highway speeds (65-70) it is a bit louder than just the Borlas but not unbearable and certainly not so loud as to not be able to hear my passenger talk to me.
Though I have to admit there are three things I have done to limit the noise in the cabin -- 1) Insulation mod, 2) 3" foam partition, 3) stuffed fiberglass insulation up in the rear wheel wells per Evil-Twin's Tire noise reduction write-up.
Your best bet is to get with someone in your local club that has the setup you want and get them to take you for a ride.
Good luck in your quest for mucho noise outside with minimal noise inside the cockpit.
2. One remedy is to purchase a trunk partition - but not the Eclkers type as it is thin and usless (IMO). Caontact Andy at 21st Century MC (972 417 7177) and get one of his - it will assist in remedy of your issue.
Here's mine installed
Lg's with GHL bullets (6" cans) no cats and it is loud but only resonance is right at 70 mph so I doubt you are going to cure your problem with the stingers!
All I do is put her in 5th or wind it up to 75 and all is well.
They sound a little like the '60 Vette i had and also like the boat i had with straight pipes. But then i liked the sound of both of them
Not "exactly" the sound i would like but got a great deal on Ebay, love the Pro Tip looks....and no resonance or drone if that's what you want.
May just make it louder.
