for the money you will dump in it you could buy a decent 97-99 I'm sure.. I am guessing the frame is bent, the cradle is cracked and there is more that we can't see.
-=Rick
I'm sure it would only be in the $20k range to get back on the road...
Exactly. That Vette is NOT a fixer upper. The car is destroyed, and not worth the effort. You would most likely spend more getting it half way decent than you would buying a low mileage one in great shape.
This is a project for one experienced in frame replacement, welding, straightening, engine (and, mechanical), suspension, and, body repair work. This project is NOT recommended for the novice. Be careful.
No matter how well you did on the repairs it would always be a previously wrecked Vette with low resale.
A couple of months ago there was a repaired salvage that was selling for 14k that was still on the market when I stopped looking because I had found the one I was looking for.
To give you an idea of what you might spend fixing this up look here.
It undoubtedly has a Salvage Title which makes it worth much less than one with a clean title. You would probably never get what you had invested back.
