Key fob problem
Old Oct 12, 2005 | 08:47 AM
VA CORVETTE 757's Avatar
VA CORVETTE 757
Default Key fob problem
Everytime I go out to my car to unlock it, i have to reset my key. As soon as I get out of my car to lock it, it already does not work again. I changed the battery as well and it is still doing this. Any clues???
Old Oct 12, 2005 | 09:27 AM
rwlc5's Avatar
rwlc5
Have you tried standing close to the front of the car and holding the lock and unlock buttons down together for about 7 seconds until the horn chirps? This synchronizes the remote with the car. I just had to do this because my car battery ran low after sitting for about a month.
Old Oct 12, 2005 | 09:45 AM
C5 4 ME's Avatar
C5 4 ME
I had similar problems with mine. I finally bought a new FOB and have had no problems since. If your remote is the original from 1997, it sounds like that may be your problem. Hope this helps.
Old Oct 12, 2005 | 09:46 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I assume you are doing the above procedure when you say 'reset your key'. If this is the case and it keeps loosing it's programming it may be that...
The contacts inside the fobs, at least on the <'01 fobs, are pretty flimsy. Open up the fob and look to ensure the + and - contacts are not touching and bend them accordingly. Mine stay programmed for the most part but if I drop my fob I almost always have to reprogram it and I assume this is because the contacts lose contact with the battery or touch each other.
Old Oct 12, 2005 | 10:18 AM
jedicowboy's Avatar
jedicowboy
Same problem here. My FOB was kaput
Old Oct 12, 2005 | 11:41 AM
VA CORVETTE 757
Yea I reset it for the 7 seconds, that's what i mean by reseting it. Yea I tried adjusting the contacts, I could try again but i probably need a new Fob.
Old Oct 12, 2005 | 11:46 AM
corvetteman39's Avatar
corvetteman39
Yup I'm having the same problem with mine to and I have a 2000 model. I've tried everything including taking an eraser to where the contact is made and that didn't work either, so I'd say we both need new fobs.
Old Oct 12, 2005 | 11:55 AM
kwest2u's Avatar
kwest2u
Default Bought new fobs
from ebay. think each ran about $15 and that included shipping. Had no problem programimg them with the DIC.
Old Oct 12, 2005 | 12:34 PM
corvetteman39
How abou a link for that?
Old Oct 12, 2005 | 12:53 PM
kwest2u's Avatar
kwest2u
Default Go to ebay
type in corvette key fobs. It will give you a bunch of choices. Bought mine from a place called remotesuperstore.
Old Oct 12, 2005 | 03:36 PM
corvetteman39
Thanks I checked it out mine is $30 but need to get ahold of a friend for his ebay account. I don't want to set one up cause I don't buy alot online.
Old Oct 12, 2005 | 03:37 PM
themosjohn's Avatar
themosjohn
thanks for the 7 second tip, i was wondering, thought i'd left something unconncected somewhere....
To Key fob problem
