antifreeze flush/refill
Old Oct 12, 2005 | 09:50 PM
vettmanjj's Avatar
vettmanjj
Default antifreeze flush/refill
What's a reasonable price for having antifreeze flushed and replaced at a GM dealer? Pros/cons of using genuine GM vs Prestone's GM compatible "red" fluid. Any and all recommendations appreciated.
Old Oct 12, 2005 | 10:38 PM
LoneStarFRC's Avatar
LoneStarFRC
On my second fill of Dex-Cool. No problems of any kind as long as the system is kept full. Filling a little above the "cold" fill level is recommended. I like distilled water as my mixing water. Cost? Not too sure, but I would think somewhere around $30 or $40 at the stealership.
Old Oct 12, 2005 | 10:41 PM
I paid $40 to have mine flushed/filled at my local dealer earlier this year.
Old Oct 12, 2005 | 10:43 PM
corvetteman39's Avatar
corvetteman39
Mine was free since I have a best friend who is a full blown mechanic. Couldn't tell you a price but I use the Dexcool also with distilled water.
Old Oct 13, 2005 | 01:09 AM
01QuickSilver's Avatar
01QuickSilver
Let me get this straight........ You want a REASONABLE price from a dealership???
I just did mine last week - cost me about $18 (2 gal. Prestone red) and about an hour of time. I was dreading the job since the Vette is somewhat "unconventional" compared to my other vehicles I have done, but now having done it I'd have to say it was one of the easiest. I flushed the block, radiator, and heater core both ways, refilled and had no problems with trapped air. I have driven it 300 miles since and no leaks or overheating so I guess it was a success.
"I love it when a plan comes together"
Old Oct 13, 2005 | 03:40 PM
FKING1's Avatar
FKING1
I paid $127 at one of Detroit's largest Vette Dealer. Chemical flush and fill with DexCool. In talking with several other owners,$100 is a typical price. Don't know if one calls this reasonable or no. This dealer tends to be high for service work.
Fred
Old Oct 13, 2005 | 04:23 PM
vettmanjj's Avatar
vettmanjj
Thanks for all who responded to the original post re. coolant replacement. I just called Pohanka Chevrolet (where I purchased my C5) here in Northern VA, and they charge $160 with their Dex-cool; $130 if I bring mine. What a rip-off. Does anyone have the name of someone that could be trusted to do this correctly here in Northern VA/Fairfax County?? Thanks
Old Oct 13, 2005 | 05:05 PM
Vette_Fan's Avatar
Vette_Fan
I done the same... about 1000 miles ago..
Old Oct 13, 2005 | 06:47 PM
LoneStarFRC
Fred
TENDS? Dayum, did he at least give you a kiss when he finished with you?
Old Oct 13, 2005 | 07:21 PM
edensknight's Avatar
edensknight
Best advice is to call around (Chevy Dealerships) and compare. Good luck.
Old Oct 14, 2005 | 04:16 PM
Lancer033's Avatar
Lancer033
...compare their rip off prices, then do it yourself
I'm sorry, I know there are good dealers out there, but there are so many bad ones that I don't even bother to attempt to shift through all of the BS anymore
Old Oct 16, 2005 | 06:09 PM
Vette_Fan's Avatar
Vette_Fan
DO you wash your car yourself or take it to a car wash? If you take your Vette to a car wash, then let the dealer do this for ya. Cuz you prolly don't bond with your car like some of us do. But is you spend time detailing it yourself, then you can do this one too.
Flushing the old coolant and refilling it would take less time that you'd spend in detailing your car. Just open the dain plug a the bottom (drivers side). Its on the corner of your radiator, a plastic plug. Keep your heater running to the max. Fill the fresh water from top, while the old water/coolant runs out from the bottom. After the clear water runs, stop pouring more water and let it all run out. When all the water is run out, plug the drain plug by pushing it back into its place and tighten it. Add 1.3 Gallons of coolant, and the rest water to bring it to FILL level in the container. Thats it. Drive the car, let it run at nomal temps. After it cools, check the level of coolant. Add some more if needed.
Or pay the dealer a hunderd and fity bucks or more to do this.
Old Oct 16, 2005 | 06:20 PM
Cpe04's Avatar
Cpe04
Old Oct 16, 2005 | 06:25 PM
rcs128's Avatar
rcs128
[QUOTE=Vette_Fan]DO you wash your car yourself or take it to a car wash? If you take your Vette to a car wash, then let the dealer do this for ya. Cuz you prolly don't bond with your car like some of us do. But is you spend time detailing it yourself, then you can do this one too.
Flushing the old coolant and refilling it would take less time that you'd spend in detailing your car. Just open the dain plug a the bottom (drivers side). Its on the corner of your radiator, a plastic plug. Keep your heater running to the max. Fill the fresh water from top, while the old water/coolant runs out from the bottom. After the clear water runs, stop pouring more water and let it all run out. When all the water is run out, plug the drain plug by pushing it back into its place and tighten it. Add 1.3 Gallons of coolant, and the rest water to bring it to FILL level in the container. Thats it. Drive the car, let it run at nomal temps. After it cools, check the level of coolant. Add some more if needed. [QUOTE=Vette_Fan]
Um, isn't that a little unfriendly to the environment?!?
Old Oct 16, 2005 | 06:28 PM
rcs128's Avatar
rcs128
Umm... isn't this process a little cruel to the environment?!?
Old Oct 16, 2005 | 08:37 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Fred
Paid the same price for the power flush, well worth it, IMHO
Old Oct 16, 2005 | 08:47 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
What's required to flush the system both ways? And how much Dex-Cool is required for a 50/50 fill with water?
To antifreeze flush/refill
Old Oct 16, 2005 | 08:49 PM
racecar2001's Avatar
racecar2001
Ok, I may be stupid but isn't a power flush and just draining a refilling not the same thing
Old Oct 17, 2005 | 01:18 AM
Lancer033's Avatar
Lancer033
after you drain it, you can just poor water through the open system and clean it out if it even needs it.
for those that want to do it "by the booK"---
Caution
With a pressurized cooling system, the coolant temperature in the radiator can be considerably higher than the boiling point of the solution at atmospheric pressure. Removal of the surge tank cap, while the cooling system is hot and under high pressure, causes the solution to boil instantaneously with explosive force. This will cause the solution to spew out over the engine, the fenders, and the person removing the cap. Serious bodily injury may result.
Important
If the procedure below is not followed a low or high coolant level condition and/or vehicle damage could result.
1) Park the vehicle on a level surface.
2) Remove the surge tank cap:
3)Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
4) Place a drain pan under the drain fowl.
5) Open the radiator drain fowl.
6) Allow the cooling system to drain completely.
7) Inspect the engine coolant for the following:
Discolored -- follow the flush procedure below.
Normal in appearance -- continue with the next step.
Notice
When adding coolant, use DEX-COOL® coolant. If silicated coolant is added to the system, premature engine, heater core or radiator corrosion may result. In addition, the engine coolant will require change sooner-at 50 000 km (30,000 mi) or 24 months.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
8) Close the radiator drain fowl. Tighten.
Tighten the radiator drain fowl to 2 N·m (18 lb in).
9) Fill the cooling system through the surge tank.
10) Fill the cooling system with a 50/50 mixture of DEX-COOL® coolant and deionized water.
11) Start the engine.
12) Allow the engine to idle for 1 minute.
13) Install surge tank cap.
14) Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant temperature reaches 99°C (210°F).
15)Shut off the engine.
16) Remove the surge tank cap.
17) Start the engine.
18) Allow the engine to Idle for 1 minute. Fill the surge tank to 12.7 mm (0.5 in) above the COLD FULL mark on the surge tank.
19) Install the surge tank cap.
20) Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant reaches 99°C (210°F).
21) Shut off the engine.
22) Remove the surge tank cap.
23) Top off the coolant as necessary, 12.7 mm (0.5 in) above FULL COLD mark on the surge tank.
24) Rinse away any excess coolant from the engine and the engine compartment.
25) Inspect the concentration of the engine coolant.
26) Install the surge tank cap.
Old Oct 17, 2005 | 02:07 AM
01QuickSilver
I used 6 1/2 qts. of Dex-Cool (manual says system holds 13 qts.) & my garden hose.
The difference between FLUSHING and REFILLING is:
Flushing uses water under pressure to rinse all of the old coolant and corrosion, sediment, etc. out. Refilling is just that - refilling. Also, if all you do is drain the radiator & refill it you will be leaving the block and heater core full of old coolant!!
I'm sure there are many who could provide a more technical sounding description, but here's how I FLUSHED mine BOTH WAYS:
Set heater temp to full hot (90)
Open radiator drain
Remove both radiator hoses @ water pump
Remove both heater hoses @ water pump
Remove water pump inlet housing (thermostat is part of the inlet).
Flush water through both heater hoses - this does the core both ways.
Plug the heater hose fittings on the water pump (I stuffed shop towels in) and flush water through the water pump where each rad. hose goes - this does the block both ways
Flush the resevoir tank
Flush water through top & bottom rad. hoses - this does the radiator both ways
Close radiator drain, connect all hoses. Leave the inlet hsg. off the pump for now
Pour Dex-Cool in resevoir very slowly until it gets up to the bottom of the hole where the inlet/therm hsg goes - (much like filling a manual trans) - this eliminates much trapped air
Install inlet/therm hsg, lower rad. hose & finish filling - total of 6 1/2 qts. Dex-Cool first, then finish with water
Run engine to operating temp with cap off resevoir while checking for leaks, shut off engine and let it cool down
After engine is cool add water as needed & install cap
Check level & top off after the next few times you drive until it stabilizes
Smile as you think about how much $$$ you saved
