1st 2nd and 3rd
Old Oct 13, 2005 | 05:27 AM
l80ous's Avatar
l80ous
Default 1st 2nd and 3rd
Who uses these gears manually on a C5 auto?
Had a go the other day and it seems quite good, makes the car sound better as well through holding the gears longer.
Can it harm the car if you push it hard in manual providing you dont take it into the red?
Old Oct 13, 2005 | 06:26 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I have a 6-speed, but I would think that you could have your car re-programed to shift at the maximum rpms without having to shift it manually. It shouldn't hurt the transmission unless you push it past the redline. Maybe someone with an automatic transmission will chime in.
Old Oct 13, 2005 | 06:40 AM
ebubman's Avatar
ebubman
have an a4; truth be told, i never did it. this is probably anathema here but i don't miss shifting after doing it for 15 yrs in our wrangler. bub
Old Oct 13, 2005 | 07:03 AM
Husker67's Avatar
Husker67
Since I enjoy the same thing, I bought a 6 speed!
Old Oct 13, 2005 | 09:13 AM
DeeGee's Avatar
DeeGee
I manually shift down occasionally as the kick down can be a bit rough. probably wouldn't do it as a matter of routine though.
From what the experts say in previous posts, the 3rd to 4th is the area where most failures occur.
To 1st 2nd and 3rd
