corsa install torque question
Old Oct 14, 2005 | 12:45 AM
okbkvette's Avatar
okbkvette
Default corsa install torque question
ok, I'm set up, going to install my new corsa pace car tomorrow night. I know I need to loosen and drop the sway bar and heat shield. Does anyone know the torque to take these two when you re-install?
Old Oct 14, 2005 | 01:14 AM
Silver98's Avatar
Silver98
Rear Stabilizer Shaft Bolt 54 N·m 40 lb ft
Rear Exhaust Hanger Bolt 50 N·m 37 lb ft
Exhaust Muffler Hanger Frame Nut 16 N·m 12 lb ft
H-Pipe to Rear Pipe bolts 50 N·m 37 lb ft
That ought to do it for you
Old Oct 14, 2005 | 09:37 AM
Bills03Coupe's Avatar
Bills03Coupe
You do not have to remove the heat shield. Remove the rear stabilizer bolts and nuts and re-torque as follows:
Rear stabilizer bar lower clamp NUT, 70 Ft/lbs
Rear Stabilizer upper clamp BOLT, 49 Ft/lbs.
Exhaust muffler hanger nut, 12 Ft/lbs. (be careful not to push these up in the body when replacing the nuts!)
H pipe bolts, 37 ft/lbs.
Old Oct 14, 2005 | 10:02 AM
okbkvette's Avatar
okbkvette
thanks
To corsa install torque question
