My Vette got flooded
Thanks,
Ken
I have three observations for you:
1. Although I am normally extremely anti-dealer, I think taking it to a Chevy dealer is a good move in this case. This will provide you with brand new OEM parts. Although this damage is not a warranty item, OEM parts AND thier installation are. If there are future problems with any of the replaced parts or the installation thereof, the dealership and/or GM will stand behind them. If GM finds out the car had water damage, they would most likely cancel your entire warranty on the whole car unless you had it fixed by a dealer.
2. It is essential that you develop a good relationship with the adjuster. He will have the power to determine what gets replaced and what doesn't. An honest and sincere attitude on your part can make a big difference on his view of your claim. If he feels you're trying to screw him, he will see through you and turn the tables on you. Keep in mind he has probably seen tons of water damage lately and hopefully is aware of the electronic nightmares water can cause.
3. Even if the car is repaired to your complete satisfaction and you never have any problems with it, the fact that it was in a flood will lower the value of it. I don't know how it works in your state, but in Iowa if a car has more than $3000 damage, the title is branded and that must be disclosed to future buyers. Read the fine print of your policy to see if that loss of value is covered, it may or may not be...
Good luck & keep us informed
- Wisdom
Do you know how far the water came up? Mine came up to the center console. Trust me you'd rather have it totalled as future electrical problems will be a nightmare. If it got in the footwell, most likely it submerged the fuse box and computer located in the passenger-side footwell compartment. Geico told me if it "hits the dash" they total it.
PM me if you want some advice that may help in dealing with the adjuster....I had a really good experience. Take your own pics just in case.
Good luck.
Broad brush statement, but flooded cars are never the same, no matter how much work is done to recover them. Especially the high tech cars. Make sure the car is carefully checked out by a competent Vette mechanic before you sign off that the insurance claim is final. Good luck
Thanks,
Ken
Sorry to hear about your problem, by your description I would hazard a guess that the water got into the Body Control Module and perhaps the Engine Control module. I had water leak onto the BCM from the AC and it prevented anything from working. I would suggest you remove the BCM and dry it out as well as the connectors as a starting point to see if it will start. I would not worry about the drive train so much, the way I see it if oil can't get out water can't get in.
Mike
Thanks,
Ken
talk to a vet (newer) vet mechanic and he will tell you about all the electronics and flooding sell it, get another, and dont look back
I just hope the Ins. Co totals this thing, otherwise the next owner is going to be a permanent fixture in the Tech Forum, all the while complaining to anyone who will listen about the electronic nightmare his C5 is.....
Seriously, you may be pleasantly surprised to find that there isn't as much damage as you think. You had no control over what happened, so don't beat yourself up over it.
Thanks,
Ken
Got your PM over the weekend. I'd be real concerned that they are not totalling the car and would start becoming "real interested" on what's being replaced. Think about what parts of the car were underwater and I would want all electrical and fabrics replaced. My water line was up to the center console and the car was totalled.
Just sent you a long PM. Take a read and feel free to call me.
Charlie
Also, aren't there vents for trans & rear axle? Depending on how deep, there could be water inside as well.
I would hope for a total. Once you have an intermittent electrical problem that calls for a tow, you will never enjoy your car again. You will always have that on the back of your mind.
Rogers in Orlando and others have clean, late model, low mileage C5s. This could be time for a C6 as supply/price curves cross. You are going to be out money, but what is peace of mind worth?
Good luck.
Thanks,
Ken
I'm hoping it will all work out for the best!
