Simple Radio Question
Old Oct 16, 2005 | 02:31 PM
l80ous's Avatar
l80ous
Default Simple Radio Question
Is the Radio/CD player ment to get louder in volume if you acclerate hard?
Old Oct 16, 2005 | 02:41 PM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Yes. There should be a **** so that you can adjust this feature to your liking. It should be on your volume control ****, an outer ring that you can turn up or down to compensate more or less for speed. I think it's called speed compensation volume (SCV). Check your manual also.
Corvette00Car's Avatar
Corvette00Car
It has nothing to do with acceleration. When the ambiant noise goes up the radio gets louder.
Old Oct 16, 2005 | 02:42 PM
landl's Avatar
landl
From: Portland, Oregon . To err is human, to forgive is NOT company policy
yes.
you set the left **** to SCV. Speed Volume Control. it increases volume relative to speed.
Old Oct 16, 2005 | 02:55 PM
ebubman's Avatar
ebubman
this scv was probably invented by a guy whose wife really yelled at him a lot!! bub
Old Oct 16, 2005 | 02:59 PM
Joe Diver's Avatar
Joe Diver
CF Enhanced Member
Cruise-In VI Veteran
St. Jude Donor '06
That would be the PSCV....Passenger Seat Compensated Volume....now, if they'd only invent a "mute" button.....
Old Oct 16, 2005 | 10:30 PM
The owners manual states with SCV, your audio system adjusts automatically to make up for road and wind noise as you drive. Set the volume at the desired level. Turn the control ring beind the upper **** clockwise to adjust the SCV. Then, as you drive, SCV automatically increases the volume as necessary to overcome noise at any particular speed. The volume level should always sound the same to you as you drive.
To Simple Radio Question
