Side Molding Question
Old Oct 21, 2005 | 08:01 PM
longc5's Avatar
longc5
2nd Gear
Default Side Molding Question
Hey guys! New to the forum here I'm looking to get a C5 and was wondering why some have side moldings (on each door) and some don't. If I do end up getting one with the moldings, can the moldings be removed? If so, any tips to get that done in the cleanest way possible?
Any help would be appreciated. Thanks!
Old Oct 21, 2005 | 08:06 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Welcome to the forum with some of the greatest people on the planet ... except for that one guy
Some technical terms for them are "Spears, those side thingies, and those long, narrow things on the doors." We just call them BSM's (Body Side Moldings). They are totally preference.
Yes. You can remove them. Blow dryer to heat them up, some fishing line to cut the 3M tape holding them one, some adhesive remover (safe for plastics... I use Goo Be Gone) and voilà! Depending on the age of the paint, you may need to remove oxidation from the door to match the paint which was under the BSM. Some people leave them on in fear of this.... but it can be done right.
Enjoy your stay and don't forget to wave
Dave Q.
Old Oct 21, 2005 | 08:09 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Dave Q.
Welcome aboard!
RonJ's Avatar
RonJ
They are an option on a C5, I don't remember the RPO for them.
They are glued on, if they've been on for a while and you take them off, you'll probably have a stripe where the paint isn't faded. Some colours show it worse than others.
RonJ ...
Old Oct 21, 2005 | 08:13 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
The body side moldings were a $75 option (B84) from the factory. $300 if dealer installed.
Tom
Old Oct 21, 2005 | 08:17 PM
MyOwn69's Avatar
MyOwn69
RonJ ...
I agree with the cheers - but not the "fear factor" about the paint!
WAY too many postings about success - and the "occasional" scare story!
I took mine off - the dreaded "millinium yellow" - and NO sign of problems.
Go for it!
Old Oct 21, 2005 | 08:19 PM
J Z06's Avatar
J Z06
the better one's have them OFF! smoother/cleaner lines. JMHO
Old Oct 21, 2005 | 08:29 PM
dyeggy's Avatar
dyeggy
St. Jude Donor '10-'11-'12, '14-'17,'21, '25
BSM's suck
Of course that is only my opinion
Old Oct 21, 2005 | 09:20 PM
Dark-Knight's Avatar
Dark-Knight
Originally Posted by dyeggy
BSM's suck
Yeah, I share that opinion...
Old Oct 21, 2005 | 10:29 PM
GrayC5's Avatar
GrayC5
Welcome to the Forum and good luck finding the right C5.
Old Oct 21, 2005 | 11:54 PM
rkhegler's Avatar
rkhegler
You can remove them yourself. I took a sharp, long bladed kitchen knife and they were off in about 10 minutes, no problem. Make sure you keep tension on the molding so you don’t scratch the surface of the door. Then, I used some WD40 to get the remaining sticky adhesive off. Finally, I use a really good car wax and rubbed out any fade. It looks great. I highly recommend it.
Old Oct 22, 2005 | 12:19 AM
longc5's Avatar
longc5
2nd Gear
Thanks for the info guys! I'll make sure I use the tips when that day comes (will be soon hopefully)
Old Oct 22, 2005 | 12:55 AM
jrose7004's Avatar
jrose7004
Wow!
Old Oct 22, 2005 | 02:04 AM
Shylor's Avatar
Shylor
They started out as a $75 option but changed to a $150 option in 2002.
Old Oct 22, 2005 | 07:24 AM
ebubman's Avatar
ebubman
bsm = a love or hate proposition. one of my criteria when we went c5 shopping was no bsm. good luck w/ your search. the car will be everything you imagined it to be & more. bub
To Side Molding Question
